I have the engine wine at medium speed and higher I put up with it cause I was on a harley.... But I do notice that when I put on the front brake I get a noise mostly when I come to a complete stop and I squeeze a little harder.. Does anyone else have this problum RonaldE:12101:
I had similar front brake noises that started on my trip to the International rally in Arkansas. It seems to have cleared itself up.
I asked a couple others about it, and they suggested I picked up a grain of sand or spot of tar/grease on the pad that might wear itself off soon. It did. But I first closely examined my pads to make sure they were still thick enough.
I had a grinding metal on metal sound with slow speed stops with the front brake for quite some time. The OEM pads still had around 50% left compared to a new pad. The noise would come and go but over several months it would be more come than go. Very annoying when you come to a stop in a group. Sounds just like worn out brakes. My solution was to replace the pads and scotch brited the rotor. I have not had any noise from the front brakes now for the last 1 1/2 years now. A friend said the old pads had "glazed". He said the only thing to do is simply replace them when that happens. :080402gudl_prv:
