83 to 85 are interchangeable, as are 86 to 93.
yamaha part#s are
1984 right front and rear 26H-25831-01-00
left front 26H2583101-00
1987 right front 1NL25831-00-00
left front 1NL25831-10-00
rear 1NL25830-52-00
The two will not fit each other.
different part#s, and look different in the yamaha parts fiche.
try ebc. i bought a new rotor for my 89, $162 plus shipping.
I think freebird had one from an 83 a while back, depending on which one you need.
If he cant help ya I'm sure somebody here can.
As trucker noted, they are different. The trick is to find a set of lower front forks from an 86/93 and change them out. Then you can go with later rotors, calipers and even with R1 calipers if you want to. You would need to wire up the anti-dives, but they would have to be better than the ones on the 83/85's.
RandyA
