Thistledown Posted August 17, 2009 Posted August 17, 2009 Well, just got back from a great trip to Vogel and I see some oil coming from the rear shock. Couple of questions, am I correct that the material and labor should be covered by warranty, the bike is an 06 ? Second thing, would I be wise to remove the trailer hitch before the dealer sees it ?
Eck Posted August 17, 2009 Posted August 17, 2009 Yes to answer both questions... I have known members to have thier rear shcok removed that did not remove the trailer hitch, however, if you happen to have the old frame bar then I would remove th ehitch so it eliminates any chance of hassel from the dealer.. but you do not have to.. this is just my opinion. The dealer will replace the shock under warrenty.
Al Bates Posted August 17, 2009 Posted August 17, 2009 [ame=http://www.venturerider.org/forum/showthread.php?t=39642]2nd gen shock help - VentureRider.Org[/ame]
SteveP Posted August 17, 2009 Posted August 17, 2009 The shock on my '06 was replaced under warranty (parts & labor). The trailer hitch is your call, but I would think it best to remove it to avoid any issues with the warranty work (Yamaha could say that pulling a trailer is not "normal" use/wear if they wanted a reason to deny coverage under the warranty).
midnightventure Posted August 17, 2009 Posted August 17, 2009 The shock on my 02 was replaced under warranty but I had to wait till it was leaking air bad before they would do anything.
cecdoo Posted August 17, 2009 Posted August 17, 2009 Just had the shock on my 06 replaced, free of charge, just showed them the oil leak. Craig
SteveW Posted August 17, 2009 Posted August 17, 2009 just had my 05 replaced under warranty and had the sidecar on it. No questions asked or problems. they just complained that they had to do it on the floor instead of the lift.
