Those things been around for years. I don't think they can handle anything as big and heavy as the Venture.
I didn't read the information but it looks scary to me.
BOO
alot of bikes can`t be hauled that way cause of damage to to tranny. no lub if engine not running. i read were ventures are one of them.i check into more before you buy one.
For a RSV...You probably would want to pull the drive shaft out so it would not spin all the stuff in the tranny. I think you could damage something if you did not do something to stop all that from spinning. You may not notice it immediately but I think you would decrease the life of the bike. If it was chain drive bike...pop the chain off.
Really I would not put any of my bikes in that thing...chain, shaft or belt drive. :confused24:
:thumbsup2::thumbsup2::thumbsup2:
:scared:
:thumbdown:the trany bearings are lubed by the oil pump when running to tow it in that maner will be a bad idea . dont do it!
shaft-driven?????? ya gonna unhook-it--------------------NO NO NO NO---
OK, so one of you mechanically inclined, metal working guys come up with a "cheap" but viable high speed dolly for the rear wheel and we be in bidness!! :lightbulb: Can we get an O - TAY!! in the house?
JC Whittney sold them years ago, called "traile a bike"
only used on small bikes, upto 500 lbs, and you had to remove the chain, so the back wheel rolled free
I tried something like this in back 1981 with an FLH. I made it a whole 10 feet before the trailer hitch bent like a wet noodle. This sort of thing would take a very beefy hitch and bumper to handle a bike the size of a Venture.
You beat me to it.
That's exactly what I was thinking. Most trailer hitches have a tongue weight of 500 pounds or less. This unit looks to stick out close to 2 feet so it would cut the tongue weight capasity in half. So max tongue weight would be around 250 pounds. Venture weighs around 800 pounds. So approxametly 400 pounds on the tow unit. Hmmmmmmmm
Other thing I don't like is it doesn't hold much of the front wheel. On turns it would put a lot of stress on the front wheel. I noticed that the dirt bike leaned a little on the turns. I also noticed that they didn't even show the street bikes in the turns. Coincidence?
:scared:
Uh Oh!!!
When coming from the Hoover Dam there was a loooong down hill. I turned the engine off and just coasted for a mile or so.
I guess I won't be doing THAT again!!
craigr
What about this then??????????????????
Just because you CAN do something doesn't always mean that you should do it.
:sign yeah that:
I wonder how well this would work with the RSV.
RUSS beat me to it, I was going to say......Her feet would have to lay across the trunk!
If you see my RSV on a trailer......................CALL THE COPS, IT'S STOLEN:sign back to topic:
