Wrongway Posted August 15, 2009 #1 Posted August 15, 2009 Well, you have to come to a stop and wait a cycle or two but it's good to know that common practice has become legal. http://www.fox4kc.com/news/wdaf-run-red-lights-bikes-081309,0,6130460.story
Dano Posted August 15, 2009 #2 Posted August 15, 2009 Glad you guys are finally coming into the 21st century there, Allan!
dksmith196958 Posted August 15, 2009 #3 Posted August 15, 2009 bout time bikes arent heavy enough to trip the light............so.....u.sit....sit....sit....if your luckey someone will pullup behind u to trip it:parrots:
Wrongway Posted August 15, 2009 Author #4 Posted August 15, 2009 Glad you guys are finally coming into the 21st century there, Allan! Aint that the truth!
midnightventure Posted August 15, 2009 #5 Posted August 15, 2009 Did you read some of the comments attached to the article? No wonder they are trying to kill us, they just plain don't like us.
naturbar Posted August 16, 2009 #6 Posted August 16, 2009 bout time bikes arent heavy enough to trip the light............so.....u.sit....sit....sit....if your luckey someone will pullup behind u to trip it:parrots: actually it (usually) isn't the 'weigh' which triggers the sensor...it is an inductive loop which is interrupted by an object which changes the inductance in the field, which in turn triggers a signal change. http://www.wikihow.com/Trigger-Green-Traffic-Lights [ame=http://www.metacafe.com/watch/828731/trigger_green_traffic_lights/]Trigger GREEN Traffic Lights! - Video[/ame]
Dano Posted August 16, 2009 #7 Posted August 16, 2009 I was gonna say that BTW, if you stop with your oil pan over top of a corner of the loop, if you can see the cut, chances are you'll trip the loop. I always pull up on one of the cuts on the side, then stop at the front corner. Works most of the time........
naturbar Posted August 16, 2009 #8 Posted August 16, 2009 I was gonna say that BTW, if you stop with your oil pan over top of a corner of the loop, if you can see the cut, chances are you'll trip the loop. I always pull up on one of the cuts on the side, then stop at the front corner. Works most of the time........ I've tried zig zag pattern when coming to light in hopes to disrupt the field but in most cases not much luck. i'm going to try the magnets deal....Northern Tool has three of them (dime sized) for $4.00. Thanks for your input. http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200328197_200328197
LilBeaver Posted August 16, 2009 #9 Posted August 16, 2009 These magnets are also helpful if you are looking to collect spare metal parts in your rear tire while driving down the road.
BEER30 Posted August 16, 2009 #10 Posted August 16, 2009 When you stop (over the sensors at the light), kill the motor and then restart .The starter will activated the sensors when the starter motor gives off it's magnetic vibes . BEER30
