owenst Posted September 19, 2007 #1 Posted September 19, 2007 It looks like I amy win an auction for a set of 2004 RK Mufflers. I have a couple of questions. 1. Do the 2004's have a catalytic converter? 2. Whe sells the bracket for adapting these mufflers to the RSV? Thanks
WIKD Posted September 19, 2007 #2 Posted September 19, 2007 It seems like there is a disagreement of what year has the catalytic converters but look in the pipe. If one of them has what looks like a yellowish brick in it then it has a catalytic converter. As for the brackets Squidley sells them in the classified section here or there are plenty of posts on how to make one of 4 different styles.
Tartan Terror Posted September 19, 2007 #3 Posted September 19, 2007 I would check with Squidley. He will even drill them to specs for you depending on how loud you want them.
Squidley Posted September 19, 2007 #4 Posted September 19, 2007 I do make the brackets, but some folks like to save a bit of money and do it themselves with the couple of different ideas that are on the site. As far as the mufflers if I'm not mistaken the '05's and up have the converter due to the FI.
