Is there an easily obtainable replacement for the clutch bleed screw? Mine has been rounded and probably should be replaced the next time I bleed the clutch.
I see in BikeBandit that I can get a replacement assembly (with the rubber cover) for $19 and change. Is there a better option?
Bleeder screws are easy to get, 8 X 1.25 is the size for the Mk1. You can get them at bike shops or auto parts places. Some of us are running speed bleeders (built in check ball), in place of the normal bleeders.
Thanks guys -- you are all the greatest.
Let me order several for all my bikes and replace them all as they come up in the maintenance schedule.
