safetyguy Posted August 9, 2009 #1 Posted August 9, 2009 Is there an easily obtainable replacement for the clutch bleed screw? Mine has been rounded and probably should be replaced the next time I bleed the clutch. I see in BikeBandit that I can get a replacement assembly (with the rubber cover) for $19 and change. Is there a better option?
Rocket Posted August 9, 2009 #2 Posted August 9, 2009 safetyguy said: Is there an easily obtainable replacement for the clutch bleed screw? Mine has been rounded and probably should be replaced the next time I bleed the clutch. Bleeder screws are easy to get, 8 X 1.25 is the size for the Mk1. You can get them at bike shops or auto parts places. Some of us are running speed bleeders (built in check ball), in place of the normal bleeders.
Squeeze Posted August 9, 2009 #3 Posted August 9, 2009 Speed Bleedersare recommended here on the Board. Don't know about the fitting Partnumber there. http://www.speedbleeder.com/
Yammer Dan Posted August 9, 2009 #4 Posted August 9, 2009 SB8125L for the 1st Gens. 2nd Gens don't need Brakes!! But they call for the same except for the front brake which is SB7100s
bongobobny Posted August 9, 2009 #5 Posted August 9, 2009 Squeeze said: Speed Bleedersare recommended here on the Board. Don't know about the fitting Partnumber there. http://www.speedbleeder.com/ Well worth the money!!! Highly recommend you replace al your bleeders with them!
safetyguy Posted August 9, 2009 Author #6 Posted August 9, 2009 Thanks guys -- you are all the greatest. Let me order several for all my bikes and replace them all as they come up in the maintenance schedule.
