bongobobny Posted August 9, 2009 #1 Posted August 9, 2009 What should I buy/not buy?? I will do the steering setup and am considering a 2 tone paint job. Also want the wheel upgrade. What about the hitch? I already have a Diamond R o n the bike. What about leveling links and lowering kit?? Questions, questions...
Carbon_One Posted August 9, 2009 #2 Posted August 9, 2009 Bob I saw in another post you've decided to go with a Hannigan conversion. Hannigan uses a pair of coil over shock type shocks on their trikes. Thus doing away with the factory shock. In place of the factory shock they have a steel tube in it's place. On Don's trike at the rally, he intends to raise the bike by adding leveling links as he feels it's too low as it comes from the factory. Especialy with the Hannigan tow bar installed. Don't know if a Diamond R hitch will work with this trike. I doubt it very much. On the paint I'd deffinately go with the two tone. Not having a Hannigan trike and from just observing them I can't add any more than this but I'm sure some other owners will stop in and give some great advice. looking forward to the day you too will be "Free on Three". Larry
GunnyButch Posted August 9, 2009 #3 Posted August 9, 2009 I've been very happy with mine, the speedo is even accurate after they got finished with it. Cougar has a hitch on his.
Cougar Posted August 9, 2009 #4 Posted August 9, 2009 Bob, you will have to go with there hitch system. It involves tubes that are Incorporated to the underside that go way back up inside there. I even removed my venture dads hitch and sold it. I am not sure why you would want to lower it though, the height is just right for me. I am 5.10 (DO NOT WORRY AT ALL ABOUT MOVING THIS TRIKE AROUND) (LIKE I DID BEFORE I GOT IT) I already did ALL that worrying for you! you will be even able to push it around with your spouse on it ! Keep asking away! Jeff
Aussie Annie Posted August 10, 2009 #5 Posted August 10, 2009 What should I buy/not buy?? I will do the steering setup and am considering a 2 tone paint job. Also want the wheel upgrade. What about the hitch? I already have a Diamond R o n the bike. What about leveling links and lowering kit?? Questions, questions... Glad to see you are "coming over" to the fun of trike/outrider You will ride with a on your face
Larry M Posted September 3, 2009 #6 Posted September 3, 2009 I was looking onto having my RSV triked and have been doing quite a bit of research on the net and this site, I've sent two emails to Hannigan in Kamloops BC as they're the closest dealer for Hannigan, I've yet to get any kind of response from them! Not many Hannigan dealers here in the Northwest! I would probably want the Reverse Kit also installed if there is a good unit available? I've also called and talked to California Sidecar about their kits, they were very helpful and answered all my questions, and, they're is a dealer in Portland, OR that does ther conversions...Soooo, it seemed on the site that the Hannigan was pretty much the conversion of choice?? I have a friend that just bought a new Harley Trike and I'm not very impressed with it and I don't think at first he was either, but he says he's getting used to it and seems to be easier to steer although not very smooth riding! But it's a Harley! Any thoughts on the two conversions and a reverse kit?? Thanks, Larry M
Cougar Posted September 3, 2009 #7 Posted September 3, 2009 Larry, There are no reverse kits at this time for the RSV. That was my biggest concern/worry when switching over. Come to find out after the conversion the bike is so easy to push around even with the wife on it as well. I always pull into the garage front first and then when I go riding I grab the light-bar up front and it rolls backward with ease! I can even be on the trike and push it with my legs easier then I could when it was 2 wheels. (no balancing act now). Now you asked about the smoothness... after about 300 miles the shocks break in and the ride is real nice. at first I was going to adjust my rear shocks , but Hanniagan said to wait. I did and now is all good. there are 5 adjustment levels on the rear shocks on the kit. NOTE: if you do decide to convert. I highly recommend the rake kit for your steering. other wise you WILL be adding it later, Feel free to call me anytime if you want to talk more about your concerns I am so GLAD I myself did this switch! Don't think I ever rode this much in one summer before. and my jaw is still hurting from grinning so much! Good luck, Jeff
