It sounds like you are referring to the idle circuit mixture screws. If that is the case, that screw will either richen or lean out your idle circuit depending on which direction the screw is turned. That being said, I wouldn't suggest just randomly turning these screws without some diagnostics first. Many a carb has been screwed up by people trying to tune them without some decent knowledge of their inner workings. My suggestion would be hooking up with a member that owns a color tune kit AND knows how to use it. I am sure others here will chime in and color in the rest of the picture.
might be asking about this screw under the cap
above the curve of my allen wrench..
http://www.venturerider.org/rsvcarbremoval/image116.jpg
