jrcain32 Posted August 3, 2009 #1 Posted August 3, 2009 Anyone who has "triked" their bike have a good used rear shock sitting around that you don't need? I think mine may be going bad.
BigSexxy Posted August 3, 2009 #2 Posted August 3, 2009 check out this classified on here. http://www.venturerider.org/classifieds/showproduct.php/product/2246/cat/7
jrcain32 Posted August 3, 2009 Author #3 Posted August 3, 2009 I looked there BigSexy but I'm not sure it will work. I should have noted that mine is a '99 and they changed the shock after '04, according to the OEM parts list. So I guess I would need one from '99-'04 unless someone can tell me if an '08 will work. I was thinking that nothing has changed on these bikes since '99 but there are a few suttle changes like shock, running lights (blinkers), etc. I know because I ordered clear running light lenses and amber bulbs to put on my '99. I had to order them off a '05 and above because they did not offer clear in '99. The lenses were fine but the bulbs were different and would not fit the socket. So, I have a set of amber bulbs for '05 and above if anyone needs them cheap...
1BigDog Posted August 3, 2009 #4 Posted August 3, 2009 Any 99 to 09 shock will work. The difference with the 04 and up is an added vent hose. My 99 now has an 06 shock on it.
