rod Posted July 31, 2009 #1 Posted July 31, 2009 I got my new rear shock in and have a question. On the replacement shock there is an extra hose, where do you hang it? The old one lasted 90,000 miles I hope the new one does as good, wow are they proud of them $$$. Ride safe Rod
1BigDog Posted July 31, 2009 #2 Posted July 31, 2009 I hung my hose between the plastic backing behind the seat, right over the shocks schrader valve..hope you can make out the pics.
Skid Posted July 31, 2009 #3 Posted July 31, 2009 Which shock did you get? And was it your original shock that lasted 90K miles?
gunboat Posted July 31, 2009 #4 Posted July 31, 2009 just like jeff did, works good for me. best reguards don c.
V7Goose Posted July 31, 2009 #5 Posted July 31, 2009 (edited) Your shock came with a gray plastic clip that sticks onto the frame right next to the negative battery terminal. Looking down on it, the clip just looks like a big O open on the top and bottom. The hose runs up the right side of the battery and the down-turned end goes into that gray clip. Goose Edited August 1, 2009 by V7Goose
rod Posted August 1, 2009 Author #6 Posted August 1, 2009 Thanks guys. It is Yamaha shock and so was the old one. I figgured that was it but wanted to be sure. Ride safe Rod
dksmith196958 Posted August 1, 2009 #7 Posted August 1, 2009 my local yam dealer told me they were not able to be orderd ? ? i would have to find one in the aftermarket ?
Rick Butler Posted August 1, 2009 #8 Posted August 1, 2009 Dean, This one is off a 2nd gen 2000 MM ,not a 1st gen. Rick
1BigDog Posted August 1, 2009 #9 Posted August 1, 2009 I had to hang my hose where I did because of the placement of the aux fuse panel right behind the battery. It was much easier to hang it out the rear of the seat area.
