rod Posted July 31, 2009 Posted July 31, 2009 I got my new rear shock in and have a question. On the replacement shock there is an extra hose, where do you hang it? The old one lasted 90,000 miles I hope the new one does as good, wow are they proud of them $$$. Ride safe Rod
1BigDog Posted July 31, 2009 Posted July 31, 2009 I hung my hose between the plastic backing behind the seat, right over the shocks schrader valve..hope you can make out the pics.
Skid Posted July 31, 2009 Posted July 31, 2009 Which shock did you get? And was it your original shock that lasted 90K miles?
gunboat Posted July 31, 2009 Posted July 31, 2009 just like jeff did, works good for me. best reguards don c.
V7Goose Posted July 31, 2009 Posted July 31, 2009 (edited) Your shock came with a gray plastic clip that sticks onto the frame right next to the negative battery terminal. Looking down on it, the clip just looks like a big O open on the top and bottom. The hose runs up the right side of the battery and the down-turned end goes into that gray clip. Goose Edited August 1, 2009 by V7Goose
rod Posted August 1, 2009 Author Posted August 1, 2009 Thanks guys. It is Yamaha shock and so was the old one. I figgured that was it but wanted to be sure. Ride safe Rod
dksmith196958 Posted August 1, 2009 Posted August 1, 2009 my local yam dealer told me they were not able to be orderd ? ? i would have to find one in the aftermarket ?
Rick Butler Posted August 1, 2009 Posted August 1, 2009 Dean, This one is off a 2nd gen 2000 MM ,not a 1st gen. Rick
1BigDog Posted August 1, 2009 Posted August 1, 2009 I had to hang my hose where I did because of the placement of the aux fuse panel right behind the battery. It was much easier to hang it out the rear of the seat area.
