Wizard765 Posted July 21, 2009 #1 Posted July 21, 2009 I am going to be pulling a trailer with cooler on the front. I was wondering if a coolatron would be OK. I don't know the power requirements for the coolatron and I don't know if the stator would be up to the task. So does anyone here know if this would work or should I just keep buying ice? Wayne
Guest tx2sturgis Posted July 21, 2009 #2 Posted July 21, 2009 Well, I'd pass on those. They need to pull 4 amps the whole time your keeping food and drinks cool. That means pulling 4 amps even when the bike is shut off. With motorcycle batteries rated at around 20 amp hours or so, in just a couple of hours you'd probably be push starting the bike. Plus, they use what is called a piezoelectric junction, which cools to about 40 degrees below ambient. Meaning, on a 100F degree day, it would be doing good to cool the inside to around 60F. I have used these types of coolers for years in trucks, and in an air conditioned cab, they work pretty well, but we also have 4 large truck batteries powering the unit overnite, so the truck easily starts in the morning. Accidentally leaving one plugged in over a long weekend tho, will drain even the 4 large truck batteries.
IH Truck Guy Posted July 21, 2009 #3 Posted July 21, 2009 tx2sturgis said: Well, I'd pass on those. They need to pull 4 amps the whole time your keeping food and drinks cool. That means pulling 4 amps even when the bike is shut off. With motorcycle batteries rated at around 20 amp hours or so, in just a couple of hours you'd probably be push starting the bike. Plus, they use what is called a piezoelectric junction, which cools to about 40 degrees below ambient. Meaning, on a 100F degree day, it would be doing good to cool the inside to around 60F. I have used these types of coolers for years in trucks, and in an air conditioned cab, they work pretty well, but we also have 4 large truck batteries powering the unit overnite, so the truck easily starts in the morning. Accidentally leaving one plugged in over a long weekend tho, will drain even the 4 large truck batteries. :goodpost: Exactly what Brian said......
Wizard765 Posted July 21, 2009 Author #4 Posted July 21, 2009 I wasn't intending to leave it over night. I have an adapter for the wall that I would use in the motel etc. I was actually thinking of using a relay to power it so that when the key was off it would not run the unit. Just wanted to know if the stator would power it and still keep my battery charged.
Squidley Posted July 21, 2009 #5 Posted July 21, 2009 Wayne, I'm in agreeance with Brian, just buy ice and that actually works 2 fold. The water that will be in the cooler will be cold, and I use a dew rag under my helmet. When we did our big trip in '06 going through Nevada in 100 degree temps I would take my dew rag and soak it in the cool water of the cooler and put it on. I also did that with our neck wraps and they acted like a swamp cooler and I stayed a lot cooler than if I didn't have them.
Steve S Posted July 21, 2009 #6 Posted July 21, 2009 Wayne, Not to give you a short answer, but NO. The RSV will not carry an extra 4 amps. We are doing well to get by with the minor accessories that we now carry. Just my 2 cents worth, :mo money:
Wizard765 Posted July 21, 2009 Author #7 Posted July 21, 2009 Ok... I got it. Cooler will work. Coolatron = too much draw. Now I gotta find me a cooler I like..... Hmmmm... Those stainless steel Colmans look good but pricey... Wayne
BradT Posted July 22, 2009 #8 Posted July 22, 2009 Wizard765 said: or should I just keep buying ice? Wayne Hotels have Ice machines as long as your staying there. BRad
dksmith196958 Posted July 22, 2009 #9 Posted July 22, 2009 you can go to walmart -meyers-lowes they do have a solar pannel that puts out enough voltage to run your cooler and charge your bikes battery , lot of the newer rv,s have solar grids to help maintain there batterys, go check them out......
AlbertaClipper Posted July 22, 2009 #10 Posted July 22, 2009 If heated gloves/vests/pants draw 4+ amps then why can't a cooler?
Yammer Dan Posted July 22, 2009 #11 Posted July 22, 2009 Wizard765 said: Ok... I got it. Cooler will work. Coolatron = too much draw. Now I gotta find me a cooler I like..... Hmmmm... Those stainless steel Colmans look good but pricey... Wayne I have a stainless Colman that is over 20 yrs old and still works good.
Guest tx2sturgis Posted July 22, 2009 #12 Posted July 22, 2009 (edited) AlbertaClipper said: If heated gloves/vests/pants draw 4+ amps then why can't a cooler? Read my answer posted earlier in the thread...we didnt say you CANT use an electric cooler, just thats its not a great idea. You might end up with a dead battery real quick if you leave it on when the bike is not running. And when its hot outside, they dont do a very good job anyway. Another problem is that if it rains on the cooler, especially when riding down the highway, you may be kissing the 12volt fan motor goodbye...its not waterproof. Edited July 22, 2009 by tx2sturgis
Condor Posted July 22, 2009 #13 Posted July 22, 2009 IH Truck Guy said: :goodpost: Exactly what Brian said...... Ditto.... However, we used one when we circumnavigated the US about 15 years ago, and when we parked for the night we'd plug the cooler into a 12vdc inverter in the motel room. Most of those thermal coolers come with a warning about leaving them plugged in over night.
AlbertaClipper Posted July 23, 2009 #14 Posted July 23, 2009 tx2sturgis said: Read my answer posted earlier in the thread I did read your answer but I was answering Wizards question. It shouldn't be any harder on the stator to run the cooler than to run electric clothing...which many of us do. You (and others) have offered up many other reasons not to use these coolers that make complete and total sense. That is why I don't use a thermoelectric cooler after I posed this question last year and received the same responses.
