Hummingbird Posted July 20, 2009 #1 Posted July 20, 2009 How many switched 12v wires are available in the fairing that can be used for power for a light relay? What color are they ?
BuddyRich Posted July 20, 2009 #2 Posted July 20, 2009 There's a few in there. But what you really want to do is run a 15 amp fused 14 or 12 gauge wire from the battery to the relay for your power source for the lamps. Then you can use parking lights or cig lighter to trip the relay since that uses very little power
Hummingbird Posted July 20, 2009 Author #3 Posted July 20, 2009 There's a few in there. But what you really want to do is run a 15 amp fused 14 or 12 gauge wire from the battery to the relay for your power source for the lamps. Then you can use parking lights or cig lighter to trip the relay since that uses very little power I have a switched line that I'm using for the passing lamps (red w/yellow stripe) and I just tied the LED's into that. What I want to do is access another switched power source for the reflector/LED side lights and any additional LED's I may put on the bike. When I find another switched line I take my LED's off the passing lamp circut.
KiteSquid Posted July 21, 2009 #4 Posted July 21, 2009 there is a FREE schematic included in the FREE service manual that you can download for FREE from a link on this site. Look in the left column of this page for a link called VRTech click it and follow your nose thru the 2nd Gen links.
CMIKE Posted July 21, 2009 #5 Posted July 21, 2009 Any blue wire will do it...that is your running lights. They come on when the key is on.
Hummingbird Posted July 21, 2009 Author #6 Posted July 21, 2009 Any blue wire will do it...that is your running lights. They come on when the key is on. Thanks Mike - I mudddled thru the FREE vrtech for an hour and wasn't able to find the info I wanted. BTW - I looked at the mods on your "07" :clap2: I especially like the lights UNDER your saddlebags.
KiteSquid Posted July 22, 2009 #7 Posted July 22, 2009 I mudddled thru the FREE vrtech for an hour and wasn't able to find the info I wanted. Click on the link in the thread at [ame=http://www.venturerider.org/forum/showthread.php?t=1828]THIS[/ame] link You can download the factory service manual that has the bikes schematics in it. While you are there you can download al the 2nd Generation Manuals: RSV Owners Manual RSV Service Manual RSV Parts List
