Guest curtismiller
I mostly start engine in neutral but when I start it in first gear with clutch in the bike will creep forward while starter is engaged and stop when it starts.Do I need to fix something or just make sure all starting is done in neutral. thanks Curtis
My bike does the same thing. Actually, it kind of jumps forward if I try and start in 1st gear.
But every motorcycle I have owned does this.
Somewhat normal for a wet clutch - initially the plates are stuck together, even when the clutch is pulled, but the sudden power of the engine running causes them to free up. Holding the brake should allow the plates to break free with just the power of the starter. This is the same reason you often get a clunk and jerk when you engage 1st gear the first time after starting in the morning.
Old oil makes this worse. Changing oil can help, either just fresh oil, or a different brand. But generally, I wouldn't sweat it.
Goose
:sign yeah that: :sign yeah that: :sign yeah that: :sign yeah that: :sign yeah that: :sign yeah that:
