utadventure Posted July 15, 2009 #1 Posted July 15, 2009 Ive been look through the 1st Gen manual to see if there is a shrader valve attached to the rear shock on my '88 VR. Thought I would throw the questions out here. Is there a rear shock shrader valve and if so where is it located? The class on my '88 doesn't work. I've installed Progressives in the front forks and would like to be able to add air manually until I get the CLASS working. Dave
IH Truck Guy Posted July 15, 2009 #2 Posted July 15, 2009 Ive been look through the 1st Gen manual to see if there is a shrader valve attached to the rear shock on my '88 VR. Thought I would throw the questions out here. Is there a rear shock shrader valve and if so where is it located? The class on my '88 doesn't work. I've installed Progressives in the front forks and would like to be able to add air manually until I get the CLASS working. Dave On my standard,the valve is located just above the dampener adjuster...
