V7Goose Posted July 13, 2009 Posted July 13, 2009 (edited) WARNING - this is LONG, so unless you are actually going to adjust your valves, or just like to read mechanical cookbooks, you probably should just stop here! There is a LOT involved in this job. It needs to be done, but it is probably worth whatever you local shop is charging. I'd certainly pay $200 for it if I trusted the shop, and I'm very comfortable doing the job myself. If you don't trust your shop, or don't have the money, then read on! We periodically have questions and discussions here on valve adjustments, like how often? (26,600 miles), is it really needed? (yes), how to? (read on), etc. And the tech manual, along with several other members, indicate it is a BIG job. So Ponch and I decided to organize a training session to see first-hand what was involved and find out about any surprises before we attempted to help any other members on this. And I want to really emphasize how thankful we are to BuddyRich for his wonderful loan of a shim kit and special tool, along with his selfless help of an entire day of hot sweaty work! Without him, what follows would probably never have happened: Background info: My 2005 RSV had the first valve check/adjustment done on schedule around 27,000 miles through the initial maintenance contract I purchased with the bike. Since the shop did it, I have no idea if any shim changes were actually needed, but since I saw evidence the valve cover gaskets were changed, I will assume that at the end of that service, all 16 valves were within spec. My bike now has 70,000 miles on it, putting it about 15,000 miles overdue for the second valve check. I found about half the valves either right at minimum tolerance or too tight (and three of them were significantly too tight). You get to decide how often you want to do your own bike, but I'll be doing this one by 30,000 miles each time now. Planning: 1. Order your gaskets and find tools and shims first. I wouldn't want to do this job without a valve shim kit unless I was willing to leave the bike torn down for several days to go find the right shims after measuring all the clearances. In addition, there are different ways to hold down the valve buckets to change the shims, but the only "right" way (and certainly the easiest) is to have the special tool; therefore, find or buy one before you start.The valve cover gasket is 4NK-11193-00-00, and the best price I found was at http://www.carolinacycle.com for about $18 ea. We have several members who have the tool and a shim kit (just a selection of various sizes) who may be willing to loan them. BuddyRich and Mother are two you might ask (if anyone else wants their name listed or removed here, please contact me so I can edit this post!). If you find someone to loan a shim kit, PLEASE ask them ahead of time to look at the current collection of shims, particularly the 265 and 270 sizes, to see if any common sizes are in short supply. The shims don't cost much, and in return for the loan, you really should buy at least two new shims in needed sizes before you start the job. Not only will this make it more likely you have the ones you need for your own bike, but it will make the kit better for the next use. It is hard to say ahead of time what sizes might be most needed, since every bike will change the mix. When we did four bikes on the same day, it was very interesting to see that. After the first two bikes, we had a ton of 270 shims, but not many 265 or 275. But after the next bike, there were only a couple 270s left but a big stack of 275. 2. This is a perfect time to change your coolant, so if you need it, have that on hand too. Even if you don't need to change it, you WILL need to drain about a quart, so have an appropriate clean tray and funnel that will allow you to do this and then add it back later. 3. This is also the perfect time to change your plugs, so have them on hand too. 4. Get a can of spray carb and choke cleaner. You are gonna want to pull those carbs (perfect time to set the floats too), and the #1 and #2 carbs are gonna be NASTY with oil residue and dirt. Legend has it that you can do this job without pulling the carbs, but no way I would want to try it. And besides, once you have all the other stuff off, pulling the carbs just isn't that hard. 5. You will really want to have your bike straight up for this job, so a center stand or maintenance jack is good to have on hand. This isn't required, but will be a lot easier and cleaner! On the side stand, you get some oil dumping off the left corner of the heads when you crack the valve cover loose, and more that comes out the covers in the left crank case. The oil mess is much worse if you have Leveling Links and you try this on the side stand! 6. Misc. tools: A good set of feeler gauges are obvious, but you will also need a torque wrench that goes down to 7.2 ft lbs (10 Nm or 86 in lbs), and a magnetic retrieving tool, tweezers or hemostats, and a good quality very small screwdriver (like a mid-size jeweler's driver, but stronger) will be necessary to remove the shims. I also recommend a tube of high temperature RTV 'gasket goo' to use on certain points of the new gaskets. On those feeler gauges, most sets have both inch and mm numbers, but the primary (or even increments) that it uses will be either inch or metric. You will have a much easier time of measuring and selecting shims if you have a metric set. And make certain you have a very bright flashlight - I prefer one of the new small LED ones because of the birghtness and color of the light. 7. Instructions - the shop manual is generally pretty good here, so I suggest you print out pages 3-9 through 3-13. The Job: Start by removing the basic stuff: seat, tank, lower cowlings, air filters. Since you WILL need to drain some coolant, just go ahead and pull those lower cowlings now and make taking off the air filters easier. Remove the "dog bones" connecting the front cylinder heads to the frame. Remove the air intake tract, including the rubber tubes where the air filters attach, the top air plenums, and the rubber T between the air filters (it is held on by one 10mm bolt on the right side of the frame). To get the air plenums off, you will need to first remove the metal straps on top (four screws each), and the two screws holding the crank case vent hose in the middle, then pull the hoses and wire bundles off to the side. After the clamps on top of each carb and the front clamp are loose, each plenum will just pull straight up. When taking off the metal straps, note that the inside front screw on each is longer than the other three, and be CAREFUL when putting all of those screws back at the end of this job - they will strip very easily! When you pull the crankcase breather connection loose from between the two air plenums, be careful of the little foam rings, most of them are stretched and falling apart - unfortunately they don't seem to be available in the parts breakdown. When you lift off each air plenum, there is a vent hose connected on the rear that will just pop off (watch out for the little wire spring clip - they aren't really necessary, but you don't want to have one pop off and get stuck in a carb or something). Pull all four plugs (necessary to turn the engine over while checking the valves). Drain the coolant - if not changing it, you will still need to drain a quart or so to allow the removal of the water hose from the rear head. CAUTION! The 12mm drain plug on the bottom left of the radiator is just plastic (as is the radiator), so when putting the plug back in, DO NOT OVER TIGHTEN!!!! The correct tightness is about what you can put on a clean, dry 3/8" socket extension with your bare hand. Pull the carb assembly. Start by disconnecting the fuel line behind the right rear carb and open the two clips on top of the carbs to release the fuel line that goes to the tank. Then disconnect the two overflow hoses that connect on top between the carbs and run forward to the front of the air filters. Go ahead and remove those overflow hoses completely, just pay attention to how they are routed and watch for the little plastic clip that holds them together between the carbs. At this point, all you need to do is loosen the hose clamp beneath each carb (but see the caution below) and disconnect the two electric plugs for the wires connected near the left front carb. You will find both of these plugs right up next to the frame under the large main wire bundle. The white two-wire plug is for the carb heaters, and the black triangular three-wire plug is the throttle position sensor. With the hose clamps below all four carbs loose, you can pull straight up on the assembly on each side to "pop" them loose from the intake manifolds (and this usually takes a lot of force!). With the carb assembly loose it slides straight out the left side. I generally wait until this point when the carbs are part way out to disconnect the throttle cables - access is much easier. Just loosen the long nut on each cable to allow it to slip off the bracket - as long as you don't move the small nut, the cables adjustment will not change. CAUTION! The screws on the hose clamps on the bottom of each carb are VERY soft metal. In addition, those clamps each have a metal collar to prevent you from over tightening them on the rubber boot. On most of the bikes I have worked on, at least one of those screws has been frozen so hard that the head stripped out, requiring me to drill it off to remove the clamp. If you have this same problem, stuff a rag under the clamp before you drill it off so you don't loose that little collar. The screw can then be replaced with any standard 4mm screw from the hardware store. With the carbs out, you probably should stuff a paper towel in each intake manifold to prevent anything from accidentally disappearing down there while you are working on the bike. Remove the chrome covers on the cylinder heads. Remove the plastic wire tray under the frame in front of the battery cover. This is held on by one 10mm bolt on the left side of the frame and a screw under all those hoses in front of the battery. Once that tray is off, pull the disconnected vent hoses out the back to get some needed working room above the rear valve cover. Finally, the last thing to take off before you can actually remove the valve covers is the rubber hose for the water line to the rear cylinder head (no need to take the front one off). You will need to remove the two plugs/covers in the center of the left crankcase cover to turn the engine, so now is a good time to do that. The two #3 philips-head screws are generally REAL tight, so make sure you use the correct size screwdriver to not bugger them. With the screws out, just use a very small screwdriver to work the cover back and forth on the O-ring to get it to pop off. There is a thin metal plate that will fall out as soon as the cover comes loose - it just goes back in with the ridge facing the crank, and you usually will not need to replace the O-rings on the covers. And now for the valve covers! Four flat allen-head bolts on each and they will pop off without too much effort. The gaskets are thick rubber, and they overlap a hollow cavity at the corner of each head. Just use your finger to pull of that rubber corner and then you can put a small screwdriver under there and catch the edge of the valve cover to pry it up. The rear cover will be difficult to get off, even after everything you have already removed! But just raise it as high as you can against the fuel line or other wire bundles still hanging below the frame and kinda rotate it forward to clear the cam chain. The front cover has lots of top clearance, but you need to take it out the right side to clear the water hose you left in place. FINALLY - ready to actually start checking valve clearance! MEASURING THE VALVE CLEARANCE: You can approach the measurement of the valve clearance two ways - some folks prefer to just turn the engine until they see the cam lobe pointing up for whatever valve they are checking, but I prefer to follow the more common practice of setting a piston at TDC on the compression stroke, then checking all valves for that cylinder (this is also the method from the service manual). But here is a little clue - don't get too hung up on believing everything in the service manual! There is a note in several places that tells you "TDC on the compression stroke can be found when the camshaft lobes are turned away from each other." NOT SO!!! While true for the front two cylinders, the cam lobes on the rear two cylinders will NEVER point away from each other! Seems weird to me, as I really expected the valve timing to show the identical relationship between the cams on all the cylinders for the same engine, but the facts show different. And before anyone asks, I did check my valve timing according to the manual and the index marks on the cams, and all four cams were correct. Anyway, back to the measurement. Start by turning the engine counterclockwise until you see the valves on #1 cylinder (left rear) all closed, then watch for the timing mark on the generator rotor through the observation hole to align with the mark on the crankcase cover. It is not necessary for it to be exactly perfect to measure the valves. Now you can check the clearance on both intake and both exhaust valves for #1. Since you are dealing with four valves at a time, it is helpful to write down the clearance you measure so you don't have to re-check them over and over again! If any valves need to be adjusted, I explain this in the next section. After completing the measurement and/or adjustment for #1, if you turn the crank 180 degrees, cylinder #3 (right rear) will be at TDC and ready to check (just put the socket on the crankshaft with the handle pointing to the rear and turn it counterclockwise until the handle points forward - can't get much easier than that!). When you are done with #3, turn the crank 180 degrees again, then start watching for a second timing mark to line up on the generator rotor 70 degrees later (a little less than 1/4 of a turn), now #2 is at TDC and ready to check. Finally, after checking/adjusting #2, just turn the crank 180 degrees one more time and #4 will be at TDC and ready to check. When you are done with #4, turning the crank just 110 degrees (slightly more than 1/4 turn) puts #1 back at TDC to start over. After you have made adjustments to any valve, I strongly recommend you turn the engine through several turns to ensure the valve shims are fully seated and measure them again to see if the final clearance is what you want. I found I needed to change the shims several times on some valves to get it right. By going through the 1, 3, 2, 4 sequence several times you get the chance to double-check all your measurements, as well as re-check the ones you changed. CHANGING THE VALVE CLEARANCE: Note: You will find a second person to help turn the engine VERY helpful here, especially when working on #3 and #4! To adjust the clearance you need to remove the existing shim and replace it with one of a more appropriate thickness. The majority of changes will be to a thinner shim, but you won't have any idea what the needed size will be until you get the existing shim out. Getting the tappet adjusting tool inserted the first time can be a little tricky. It can be inserted from either side of the cam, depending on which side you want to pull the shim from. The first thing you do is turn the crank in either direction so that the cam lobe is pointing AWAY from the side where you plan to insert the tool. Next, before you insert the tool, use your fingertip to turn both shim buckets until one of the open notches is where you can reach it with your small screwdriver - this is where you will need to pry up the old shim to break the suction of the oil film (and that can be tough to do). To insert the tool, try to rotate the short end under the cam to depress the buckets. You won't get it very far just with your fingers, so slowly turn the crank in the proper direction to let the cam finish turning the tool into place (while keeping some pressure on the long arm of the tool to make it move). You will want to make sure the tool is turned all the way until the long arm touches the side of the head or you won't have enough clearance to pull out the old shim. Now that the tool is in place, reach in with that little screwdriver and pry up on the bottom edge of the shim - the suction of the oil film will be STRONG, so don't be surprised if you have a tough time getting each shim to pop up. Once it does pop up, you can either grab it with tweezers or a magnet to pull it out. Turn it over and note the number on the bottom (they should always be installed with the number down). Replacement shims are only available in .05mm increments (such as 260, 265, and 270), but the ones you pull out might be be anything (such as 269 or 272). That is why you will find some odd numbers in the shim kit - they came out of someone else's bike. To decide what shim to put back in, you need to know what the clearance was before you removed it (remember, I said to write it down)! The shop manual has a really neat chart that lets you just look along one axis to find the number on your current shim, then just look down the side to find the clearance you measured - where the two lines intersect, that is the new shim number you need. It works pretty good, but make sure you look at the right chart (they are different for intake and exhaust)! If you try and do this job without having a shim kit, those charts are really the best way to decide which shims you need to buy. A less formal but more natural way is to just look at the number of the current shim, think about how much you need to change it (was that valve just a little tight, or a lot tight?), and then choose a slightly thinner or thicker shim that you think might be in the ballpark. For example, if you pull out a 273 shim and the valve was just a tad too tight, you might want to try a 270, but if it seemed quite a bit lower than the minimum spec, better go straight to the 265. No matter how you selected the new shim size, it is very important to turn the engine over several times and then re-check the clearance to see if your guess was correct - even using the charts leaves room for error. Putting it all back Together: Just a few notes here on reassembling the bike - most everything will just be a reverse of the disassembly process, but there are a few pointers to help you. Valve Cover Gaskets: These are very thick rubber with big half-circle "lumps" at the ends of each camshaft. They only go on ONE way. They are flat on the bottom, and the top has a ridge that fits into the groove on the valve cover. But it does not fit tight enough in the groove to hold it in place while you put the cover back. No matter, though, since there is not enough clearance to get the cover back on the rear cylinders with it attached - your only choice is to place the gasket on the head and then maneuver the cover in place. The original gasket seems to have been held to the cover by several spots of rubber cement in the groove, but there was no sign that a gasket sealant was used all the way around. Other than those glue spots on the cover, there was no sign that the original factory gasket had any RTV type gasket sealant used at all during assembly. However, when the shop did my valves the first time, they DID use a bit of RTV, but only on the lumps, and neither gasket ever leaked in 40,000 miles. For comparison, one person who had replaced the gasket without using any sealant did develop a slight leak at one of those lumps over time. For these reasons, I personally recommend applying just a thin coat of high temperature RTV to the depression in the head where those lumps fit before putting the gasket in place. Now look closely at the parts of the gasket where it is next to the spark plugs - on the exhaust side only you will see a slight squiggle or wave in the gasket, and on the cylinder head you will see a matching wave. Make sure you position the gasket with those points matching. Then look at the cover - notice the same wave? Guess where it goes . . . When you lower the cover down on the gasket, the challenge is to get the ridge on the gasket to smoothly fit up into the groove on the cover all the way around. If you even have a hint that the cover is not completely smooth and flush on the head, then the gasket is NOT completely seated in that groove. Take your time and trace the entire edge with a bright flashlight to get it right. Remember how much work it was to get that cover off; you don't want to have to do it again! When putting the front gasket and cover in place, remember they must go in from the right side to fit around that water pipe. The torque on the cover bolts is only 7.2 ft lbs., and that is not much. Make sure you have a wrench that has a setting that low, and use it. These are not the kind of gaskets where you can go back later and tighten them a little more if you get a leak. In fact, over tightening the cover on that thick rubber will just distort it and make the leak worse. Although the manual does not say to tighten the bolts from the inside out in a cross pattern like you would the head bolts, that is still the method I recommend. Air Intake Parts: Make sure you get that front T in place before you put the carbs in, same with the rubber Y that connects the air plenums to the T. The only thing to remember about the T is that it has a locating lug sticking out the front that MUST fit in the rubber grommet in the frame. The hose clamp on that rubber Y is located on the left side of the bike, with the head facing up. Initially it seems impossible to access, but just use a long screwdriver behind the wire bundles next to the frame. Putting the carbs back in: After making sure the hose clamps are still properly positioned on the top of the intake manifolds, slide the carbs in from the left side, but leave them just far enough out to make it easy to attach the throttle cables. Then after making sure all the carbs are centered on the manifolds, you need to push down on them pretty hard to pop them back in place. Try to put the base of your hand on top of the carb throats, not on the plastic diaphragm covers. Re-route all the fuel lines and vent hoses appropriately, and don't forget to re-connect the two plugs. Putting on the air plenums: Some people have had real trouble getting the air plenums to fit properly back on top of the carbs (and stay there when they tighten the clamps). In every single case I have seen, this has been caused by the rubber neck on the plenum being caught on the edge of the carb and buckled under the clamp - usually behind the carb where it is impossible to see. Make sure the clamps are plenty loose and rock the plenum a bit when putting it on. If the rubber is not buckled in there, the plenum will fit fully down on the carbs and not spring back up at all. Unlike the lower hose clamps, those on top of the carbs do not have a metal collar to prevent them from being over tightened, so just make sure they are properly set in the grooves on the plenum and snug them up pretty good instead of trying to play Magilla. I think that is about it. Let me know if you think I have missed something or you have any questions! Goose Edited July 18, 2009 by V7Goose
N3FOL Posted July 13, 2009 Posted July 13, 2009 I own a 95 Taurus SHO and had done my valve adjustment 2X on the Taurus. This Taurus has a Yamaha engine, so I have a feeling that the shims my car use is similar to the Venture. I also have a special tool to lift the cams in order for me to have access to the shim. Not sure if it is the same special tool that I can use for the Venture. If the Shims are the same, I now have a complete set including used ones that I replaced. If you have pics of the special tool and shim, I may be able to compare it with what I have.
frogmaster Posted July 13, 2009 Posted July 13, 2009 (edited) Friends DO NOT let Friends miss Valve Adjustments... PERIOD! You want 250,000 mile from your Venture you best do Valves every (26,000) specially if in the Magic 5 Year Window called Warranty. Nuff Said Way to go V7Goose Who can put this in the TECH Library??? Edited July 13, 2009 by frogmaster Who can put this in the TECH Library???
V7Goose Posted July 13, 2009 Author Posted July 13, 2009 Who can put this in the TECH Library??? I will, as soon as I am done fine-tuning it based on our collective memories and any other comments I get. Thanx, Goose
Sleeperhawk Posted July 13, 2009 Posted July 13, 2009 Got have way through and said, this is a winter time project.
Tom Posted July 13, 2009 Posted July 13, 2009 Glad I didnt try to write that! The only thing I would say is have the Aleve Handy afterwards..Great Job Goose!
Seaking Posted July 14, 2009 Posted July 14, 2009 I will, as soon as I am done fine-tuning it based on our collective memories and any other comments I get. Thanx, Goose Dang.. my '06 bike has turned over the 40,000 miles mark this past week and most likely never had anything done to it under warranty (US bike brought into Canada, I'm the 3rd owner).. Looks like sometime soon this bike is gonna need a lot of TLC cause I love this bike.. it's a sweeeeet ride.. Thanks Goose.. I'll see if I can manage a winter trip down lol.. Cheers
RandyR Posted July 14, 2009 Posted July 14, 2009 I ordered one of the shim tools and a set of feeler gauges 2-3 weeks ago, It was coming out of Canada, so I suppose I have to wait for the package to get thru customs. Maybe I'll get a chance to practice on someone else's valves before my own turns 26,000 miles. I see the shims on ebay, and they are the same size as my Triumph uses.
gunboat Posted July 14, 2009 Posted July 14, 2009 thanks goose great write up, looks like you covered it all. i feel a whole lot better about doing the valve adjustment now. but i sure could use a little more ojt (on the job traning). like one or two more times. the only thing i would add to you post is to have a very strong / bright flashlight maybe even one of those led head lamps. so your hands will still be free to do all the wrenchen. thanks again to all who were there. best reguards don c.
BuddyRich Posted July 14, 2009 Posted July 14, 2009 They are 25 MM shims. Same as in this auction which has Triumph as one of the makes. I have never used anything bigger the 285 and nothing smaller than 255. So some of those in that kit will be kinda of useless.Which also means you can get them at your local Honda ,Truimph, dealers .I think Kawasaki also uses them. http://cgi.ebay.com/ebaymotors/Honda-CBX-Valve-Shim-Shims-2-50-to-3-10-25mm-size_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQhashZitem5d256f0eccQQitemZ400059993804QQptZMotorcyclesQ5fPartsQ5fAccessories Honda CB750, CB750C, CB750F, CB750K, CB750SC dohc (79-83) CB900, CB900C, CB900F, CB1000C, CB1100F, CBX (all) Triumph Hinckly triples and fours Speed Triple, Tiger, Daytona, Trophy, Sprint Yamaha SRX250, XT250 TT350, XT350 (86-00) XJ600 Seca II (92-98) XVZ12 XVZ13 Venture Royale Royal Star (83-93) XVZ1200, XVZ12 VMX1200 V-Max (85-02) Vmax, VMX12 FJ1100, FJ1200 (84-93)
V7Goose Posted July 14, 2009 Author Posted July 14, 2009 Hmmm, seems like those little foam thingies sealing the crankcase vent connection to the air plenums might not be available. Has anyone had any luck replacing them? The foam rings to which I refer go around the openings on both sides of #22 in the parts breakdown below, but I sure can't find any sign of a seal or foam ring in that diagram:[ATTACH]33199[/ATTACH] Goose
N3FOL Posted July 14, 2009 Posted July 14, 2009 In the early 90's, a company in Cincinnati made a video on how to perform valve adjustments, replace timing belt, etc. on a Taurus SHO. I bought one and it is always a nice refresher to watch before I attempt another valve adjustment/check. If a video can be made for the Venture, I will for sure buy one.
gunboat Posted July 14, 2009 Posted July 14, 2009 goose those foam gaskets on my bike. 1-was oil soaked and tore appart trying to remove it and the other one was ok. but i asked ponch about his and he had left them off. this breather does fit real close in to the air box. but i will take it back apart & use some rtv to seal the box. best reguards don c.
V7Goose Posted July 14, 2009 Author Posted July 14, 2009 I wouldn't worry too much about just leaving them off - like you say, those boxes do fit together fairly tight, and even the oil mist up in there should provide an additional dust filter for whatever air gets sucked in. I have just seen so many of them deteriorated and coming apart when I help people work on their carbs I thought I'd try to find the replacement info to post in these instructions. I was surprised to not find it in the parts breakdown. Goose
GaThumper Posted July 14, 2009 Posted July 14, 2009 Great Job! I will definately be using this soon, since the '01 I bought has just turned 25k. Maybe I can wait until winter, we'll see. I just finished the valve job on my old '79 GS1000E (inline 4 with big 'ol shims!) and I bought the special tool for depressing the buckets and wouldn't have wanted to do the job without it. One of the guys on the GS Resources had created an Excel spreadsheet that was pretty nice. You entered the original clearance (in inch or mm) and the installed shim and it calculated the probable replacement shim. I'll probably come up with one for my Venture. If anyone is interested, I'll be glad to share. One comment, and this is just what I was told about the GS. They recommend NOT touching the shims with a magnet. The concern was magnetizing the shim and attracting any metal shavings/bits to the shim and possibly wearing/scarring the cam. I'm not sure if this is really an issue, or an issue that is specific to the GS, but I'll probably not use a magnet on mine if I can get them out without one. On the GS I used a small screw driver to pop them up, and a couple of different small needlenose to remove them. Thanks again for a great writeup. Together with the manual it will make the job a little less intimidating! Definately looks like a job NOT for the feint of heart. If I trusted anyone else to work on my bikes, I might pay to have it done, but to them IT's just a JOB, to me SHE's my BABY! James
Ponch Posted July 14, 2009 Posted July 14, 2009 Yeah, I left mine off cause they dissolved. I haven't looked into replacing them yet. Probably could place an O ring in there if needed. Goose, the only add-ons I would entertain is the need for a long ratchet or breaker bar while turning the crank over. With a short ratchet, its real hard to find the mark without over shooting it. The other is , I remember squiggly lines on both sides of the valve cover, both on the exhaust side, one on each cylinder next to the center. Might want verify my response. I'm old, I forget easy. Don't turn the cover around. It has to match the same orientation as the cylinder head. Article looks great to me. Ponch
RedRider Posted July 14, 2009 Posted July 14, 2009 Goose, Great writeup. Thank you. A couple of items you may want to include. 1) What is the special tool? P/N and source 2) What is the required shim kit? P/N and source (BuddyRich input seemed to have it but the link didn't work - would prefer a source other than an EBay seller even though it may cost more). 3) P/N for valve cover gasket (if needed to be replaced). 4) Valve clearance tolerances (from the repair manual). 5) How do you rotate the engine? I'm sure this is in the manual also. Does the cover exposing the nut used to rotate the engine require a replacement gasket? 6) Nut size for rotating the engine? Need to make sure we have the right socket available. Just minor details, but will make it a more complete write up. Again, very well done. Thank you for your continued excellence in sharing your Venture mechanical expertise. RR 1
V7Goose Posted July 14, 2009 Author Posted July 14, 2009 Yeah, I left mine off cause they dissolved. I haven't looked into replacing them yet. Probably could place an O ring in there if needed. Yes, I thought of the O-ring as an option, but have some doubts. It would need to be a fairly thin one and stretched a bit tight to conform to those tight corners, and even though the two boxes fit together with a close fit on the part that slides in, they do not necessarily stay pulled together. The two screws on the front where the vent hose connects keeps that side together, but the rear of the box can spread apart a little. The original foam strip takes up any variation here, but an O-ring must be compressed evenly to do any good. Goose, the only add-ons I would entertain is the need for a long ratchet or breaker bar while turning the crank over. With a short ratchet, its real hard to find the mark without over shooting it. You are right, it is difficult to perfectly align the timing marks with a short wrench, but that is only needed to check the valve timing index marks on the cams. For just checking the valve clearance, having the timing mark within an inch either direction would not make any difference. The other is , I remember squiggly lines on both sides of the valve cover, both on the exhaust side, one on each cylinder next to the center. Might want verify my response. I'm old, I forget easy. Don't turn the cover around. It has to match the same orientation as the cylinder head. Hope we are talking about the same thing here, I think we are - we may need Tom to go dig one of those old gaskets out of the trash to verify for us. From what I remember, the squiggle in the head/gasket/cover was on both sides, meaning near the plug for both cylinder #1 and #3, but it was only on one side of each plug. Meaning that if you looked down at the cylinder head with the cover off, you would see the squiggle on the edge in back of each plug on #1 and #3, but not on the edge in front of each plug. In fact, I just found a drawing on page 4-18 of the shop manual that seems to show the little wave on the head on the exhaust side of the plug for each cylinder. Your reference to it that way is much better, and I'll refine the wording. Article looks great to me. Ponch See my comments above - thanx! Goose
brainfart Posted July 14, 2009 Posted July 14, 2009 EXCELLENT write-up - wish I was a bit closer to ya'll.... Anyone in AZ have the same expertise / knowledge / patience???
V7Goose Posted July 14, 2009 Author Posted July 14, 2009 Goose, Great writeup. Thank you. A couple of items you may want to include. 1) What is the special tool? P/N and source YM-33961 - available from any Yamaha shop, or a web search identifies many providers - seems to be a ripoff price of around $70 2) What is the required shim kit? P/N and source (BuddyRich input seemed to have it but the link didn't work - would prefer a source other than an EBay seller even though it may cost more). As BuddyRich said, our shims are 25mm - to the best of my knowledge, any 25mm shim is the same, so source is immaterial - many can be found with a web search. Most starter kits seem to be around $120, but they are lacking some significant sizes, such as 265 and 275. In addition, they only have two each of the sizes that ARE there, so if you want to put together your own kit, I think it will be about $150 to start. It looks to me like most newer bikes (except Triumphs) all use much smaller shims, with the 25mm size being much more popular back in the 80s and 90s. 3) P/N for valve cover gasket (if needed to be replaced). This absolutely MUST be replaced - I will include the number before I get done. 4) Valve clearance tolerances (from the repair manual). RTFM 5) How do you rotate the engine? I'm sure this is in the manual also. Does the cover exposing the nut used to rotate the engine require a replacement gasket? Good question - the cover has an O-ring that should generally be fine for re-use, but if it ever leaks, the replacement is just a matter of two screws. 6) Nut size for rotating the engine? Need to make sure we have the right socket available. 19mm, I think - not real special. I didn't think about including it, since anyone who would tackle a job like this without a full set of metric sockets and other common tools is in for a rude awakening anyway! Just minor details, but will make it a more complete write up. Again, very well done. Thank you for your continued excellence in sharing your Venture mechanical expertise. RRI do appreciate your thoughts and comments - I've included some responses above, but I'll have to think about how much to add to the writeup - it is already way too long. I wasn't trying to write a new tech manual, just provide more detail and some clarification that it does not have. Virtually all of that information is in the manual, and that is why I provided the appropriate page numbers to print out before someone starts the job. I think I'll probably just include this and other selected posts to the thread when I move it into the tech library - that way the info will be there without making the writeup even longer. Because of the limited applicability of the stupid $70 tool, as well as the fact that newer bikes do not seem to be using those big 25mm shims, so a big investment in the kit may not get good payback, looking to borrow one seems like the best idea to me. Thanx again for the thoughts, Goose
RandyR Posted July 14, 2009 Posted July 14, 2009 http://www.oldbikebarn.com/ has the valve shim tool for $38.41. The same tool is used on the 1st Gens and origonal vMax. I have one on order from them. The Sudco catalog lists a cheaper valve shim tool but it is a mistake - the wrong tool. see thread [ame=http://www.venturerider.org/forum/showthread.php?t=37433]K&L Supply Co makes Yamaha Tools - VentureRider.Org[/ame]
V7Goose Posted July 14, 2009 Author Posted July 14, 2009 (edited) They are 25 MM shims. Same as in this auction which has Triumph as one of the makes. I have never used anything bigger the 285 and nothing smaller than 255. So some of those in that kit will be kinda of useless.Which also means you can get them at your local Honda ,Truimph, dealers .I think Kawasaki also uses them. Hey guys, I just found a neat service that will swap up to 5 shims for $12 (includes shipping). Maybe your best option if trying to do this yourself, and if you have a kit, that is a great way to get rid of those useless sizes. Here is the link: http://store.albaaction.com/shop/ALBA-SHIM-EX.html Buddy, next time I or someone else wants to use your kit, why don't you just tell them what sizes to order and which ones to return out of the kit? Goose Edited July 14, 2009 by V7Goose
RedRider Posted July 14, 2009 Posted July 14, 2009 http://www.oldbikebarn.com/ has the valve shim tool for $38.41. The same tool is used on the 1st Gens and origonal vMax. I have one on order from them. The Sudco catalog lists a cheaper valve shim tool but it is a mistake - the wrong tool. see thread K&L Supply Co makes Yamaha Tools - VentureRider.Org Is this the same tool needed for the 2nd Gen? The OBB fitment guideline did not include the 2nd Gen bikes. RR
