Aussie Annie Posted July 13, 2009 #1 Posted July 13, 2009 Can tips/ends be put on the Venture mufflers?? If so, which are recommended:confused24: I want the end of the mufflers to face DOWN a bit, due to there being a plate directly behind them on the trike conversion that may over time get heat damaged. (It covers the springs at the back) Also the rubber end of my crutches will sit near there while I ride. Don't want to pull up and find a burnt crutch!! The smell of burning rubber would put the wind up me anyway!! (is it bike trouble)
Aussie Annie Posted July 15, 2009 Author #2 Posted July 15, 2009 I take it then, there aren't any??????:smile5:
LilBeaver Posted July 15, 2009 #3 Posted July 15, 2009 I am pretty sure I have seen some... I was waiting for someone else to chime in with the info (since I would like some too). Hmmm... Rick M.
Freebird Posted July 15, 2009 #4 Posted July 15, 2009 There are none made for the stock RSV mufflers. I have seen some folks use the RSTD tips on them but it requires some drilling and tapping as the stock RSV mufflers are not designed to use them. Some of us have bought RSTD mufflers off Ebay and other places and use those. They are the same as the RSV mufflers except they have tips that can be turned out, down, etc. If you don't mind LOUD...Khromewerks does make a very nice set of mufflers with different tips available. Don
BuddyRich Posted July 15, 2009 #5 Posted July 15, 2009 Looks like with your setup there your gonna need some HD mufflers with turn down tips. Even if you put the RSTD ends on it won't change the direction of exhaust flow. Something like the cobras on this HD. http://www.online-motorcycle-parts.com/images/HAREX-DRESSERCOBTDSLIP.jpg
Sleeperhawk Posted July 15, 2009 #6 Posted July 15, 2009 As Freebird stated, Kromewerks make nice pipes with different tips, one of them being turndowns.
Condor Posted July 15, 2009 #7 Posted July 15, 2009 I wonder if a set of 1stGen turn downs might be made to fit?? If somebody will give me a measurement of the taper tip on a 2ndGen I'll take a look at a spare set I have to see if they'll slip over the end a little. Or... I'll go out and measure what I have and post the specs.... Which ever comes first....
Aussie Annie Posted July 15, 2009 Author #8 Posted July 15, 2009 Thanks for the input Guys :thumbsup2:
