Double D Posted July 5, 2009 #1 Posted July 5, 2009 OK, I am not the sharpest tack in the box so someone out there should be able to help me with this. I have the 550 and I know that you can store music on this thing to listen to--I have a 2 gig SD card and can not figure out how to keep my CD's together when I put the songs on the card. I have a 3 disk series of George Jones and want to keep each disk's songs together but when I load the disks on the SD card all the songs load by the song number. All the 01 songs are together then the 02--03 etc. How do I load the disks and keep them as they are on the CD? Is this confusing enough???
OutKast Posted July 5, 2009 #2 Posted July 5, 2009 Don't worry. Just let it put the songs on however. After you load the card into the zumu, you can use the zumo menu to select by artist, album, title, genre (country/rock/ect).
BradT Posted July 6, 2009 #3 Posted July 6, 2009 May i suggest going for a longer ride and just play all the songs on the MP3 player until you hear all the songs you want. Brad
sgripp Posted July 6, 2009 #4 Posted July 6, 2009 Double D said: OK, I am not the sharpest tack in the box so someone out there should be able to help me with this. I have the 550 and I know that you can store music on this thing to listen to--I have a 2 gig SD card and can not figure out how to keep my CD's together when I put the songs on the card. I have a 3 disk series of George Jones and want to keep each disk's songs together but when I load the disks on the SD card all the songs load by the song number. All the 01 songs are together then the 02--03 etc. How do I load the disks and keep them as they are on the CD? Is this confusing enough??? You have to Rip/Burn the CD's to disk first and then copy them in their exported folders onto the SD card. I use Nero and it works pretty good. When you Rip the CD it will copy all of the CD/Song info with the individual MP3's and then the Zumo can sort by Name/Artist/Album etc. Is actually allot easier than it sounds once you try it a couple of times.
arnesbay Posted July 6, 2009 #5 Posted July 6, 2009 Double D said: OK, I am not the sharpest tack in the box so someone out there should be able to help me with this. I have the 550 and I know that you can store music on this thing to listen to--I have a 2 gig SD card and can not figure out how to keep my CD's together when I put the songs on the card. I have a 3 disk series of George Jones and want to keep each disk's songs together but when I load the disks on the SD card all the songs load by the song number. All the 01 songs are together then the 02--03 etc. How do I load the disks and keep them as they are on the CD? Is this confusing enough??? You also have the option, before loading them to the SD card, to make a play list. This is done in Media player or in other programs for music and media by creating a list naming it and sending the songs to the play list. When done filing send to the SD card.
