I have read numerous posts on bleeding the clutch but none tell exactly how. My question is this: Do you just bleed it like a brake line? I saw a thing on reverse bleeding but I do not have a pump to do that with. I there another way to reverse bleed. I have bled the brakes on many different cars, bikes and even a tractor or two but never have done a clutch. Any help would be...um...helpful.
Thanks
Yes - you do it exactly like you would to bleed brakes. Pump it up...hold the clutch handle in and release fluid. Add new fluid and continue. Keep on until the fluid comes out clear and with no air bubbles.......... Just takes a few minutes.
Good luck!
