a warning for folks with progresive lens glasses, I had mine in the hard case in the trunk for our 100+ degree ride, as I had my sunglasses on, when I got home, I noticed I couldn`t clean them, after looking close at them, I noticed that they are coming apart where the lenses change, I now have a line and little specs that look like they have chrystalized.... so its new glasses tomorrow, at least the lenses....I have never heard of this happening before..:confused24:
Guest Saddletramp
I've worn these lenses as long as I have had to have dual perscriptions. Never had a problem. I wonder if it had something to do with heat and pressure while they were packed?
They were in a hard case so it must have been the heat.... I don`t know....
My wife works in this field she said the glasses have an anti reflective coating that is heat sensitive. If it is a better lens they can strip it and re-coated. It has nothing to do with the progressive lens other coatings like transitions will do this.
My :2cents:
I wear the transitions so I don't have to "swap".
I do however keep my previous perscription pair in the saddlebags so if something happens, I don't have to try to find a seeing eye dog :cool10:
Whatever the case may be thanks for the WARNING!! I am sure most off us would never think of this and I am sure the interior of saddlebags can get just as hot as the inside of a car when all closed up.:thumbsup2:
One summer, I accidentally left a pair of progressive lens glasses in a case in the glove box and couldn't find them. When I did 3 days later they were shattered...I figured from the heat?
