dr_bar Posted June 27, 2009 #1 Posted June 27, 2009 what type and make of pads are you using while pulling the extra weight of a trailer???
Brake Pad Posted June 27, 2009 #2 Posted June 27, 2009 venture has two types of brakes, the standard shoe, and the after market shoe, after market (Better) most yamaha shops carry both. I personal use my motor, clutch & brake together to slow me down, and I do it, way in advance
Steve S Posted June 27, 2009 #3 Posted June 27, 2009 As replacement pads I have been using EBC brand in the HH series. They give good service and provide great stopping power. Good luck with the trailer. I pulled one for 5k miles through Montana and Wyoming and never knew it was there. :080402gudl_prv:
1sttenor Posted June 27, 2009 #4 Posted June 27, 2009 venture has two types of brakes, the standard shoe, and the after market shoe, after market (Better) most yamaha shops carry both. I personal use my motor, clutch & brake together to slow me down, and I do it, way in advance Exactly! I double my stopping distance, but with the Sintered Pads, it will shut down...if you really need to!
Guest wrench Posted August 4, 2009 #6 Posted August 4, 2009 I also replaced my rear brakes 2 years ago with the EBC HH's, but does anyone else have a brake dust problem with them? It wouldn't be so bad if it was easier to get in there and clean it up. Steve, how much/if any did the trailer affect your fuel mileage? Just curious. Thanks,,,
brainfart Posted August 6, 2009 #7 Posted August 6, 2009 We just towed a modfied Harbor Freight trailer from Phoenix to Billings and back. Cruising along about 65 MPH was almost 40 MPG. Pushing it over the Continental Divide, twisties on a wide FUN strech, really workign the Avons and throttle, we averaged 75mpg. However MPG went down to 18.... .
