I bought the Stebil air horn & wiring kit last winter. I plan on putting it on this w/e.
Where do I locate the Relay? - I mean the physical location, not electrically.
craigr
Don't know if the Venture is the same as my '98 RSTC, but I took the side cover off on the right, just above the horn and mounted it to a bolt under there, under the coolant reservoir.
Not a real good picture, but the white wires with the green shields are connected to the relay.
