NCReb Posted June 23, 2009 #1 Posted June 23, 2009 I know its hot weather and no need for heated cloths, but I like to ride in cold weather too. My question is, does Yamaha make a heaver duty alternator? The reason is my bike will not keep the battery charged with my wife and I wearing our Gerbing's heated coats and gloves. Seems like a touring bike would provide ample power for heated cloths. Don't get me wrong I love my RSV and would not trade it for any other on the market. Any help in this matter would be a great help, I know ya'll are a great bunch of people and I'm honored to be a part of this forum. Mike
1BigDog Posted June 23, 2009 #2 Posted June 23, 2009 Yep, Rick at www.buckeyeperformance.com has an upgrade stator for $239.00. I installed one last year and it works great. http://www.buckeyeperformance.com/images/stator.jpg Higher Output Stator Yamaha RSV 99- & RSTD 05- XVZ1300 For those that have lots of lights and/or heated grips and clothing. We have the fix to your barely adequate OEM stator supplies. This stator is designed to give a higher output in the normal cruising range from 2000 to 3500 RPM's The OEM stator spec output is 30 amps. During testing we've seen increased output to a peak of 55 amps. No core exchange is needed these are NEW units. Each order comes with installation gaskets included. (Note: This unit requires hard wire (soldered) connection. As of 11/01/07 the Research and Development RSV has over 7000 trouble free miles of real life testing with this stator.) Part # BP426-426-HOSTAT $239.00 Click Here to order
midnightventure Posted June 23, 2009 #3 Posted June 23, 2009 Disconnect or put a switch in the carb heaters. Makes a lot more wattage available for charging.
NCReb Posted June 24, 2009 Author #4 Posted June 24, 2009 Yep, Rick at www.buckeyeperformance.com has an upgrade stator for $239.00. I installed one last year and it works great. http://www.buckeyeperformance.com/images/stator.jpg Higher Output Stator Yamaha RSV 99- & RSTD 05- XVZ1300 For those that have lots of lights and/or heated grips and clothing. We have the fix to your barely adequate OEM stator supplies. This stator is designed to give a higher output in the normal cruising range from 2000 to 3500 RPM's The OEM stator spec output is 30 amps. During testing we've seen increased output to a peak of 55 amps. No core exchange is needed these are NEW units. Each order comes with installation gaskets included. (Note: This unit requires hard wire (soldered) connection. As of 11/01/07 the Research and Development RSV has over 7000 trouble free miles of real life testing with this stator.) Part # BP426-426-HOSTAT $239.00 Click Here to order Many Thanks
