StarQ Posted June 22, 2009 #1 Posted June 22, 2009 I know a lot has been posted about the Stebel Nautilus Air Horn. I took a few pictures of my installation on my RSTD and wanted to share them. Stebelhorn1.jpg shows how I mounted the relay under the right side cover next to the coolant overflow tank. Stebelhorn2.jpg shows the wiring according to the wiring diagram included with the horn package. Stebelhorn3.jpg shows the brackets I made from aluminum bar stock. Aluminum is easy to drill and bend. Not shown in the picture is the slight bend I made in each bracket to get the horn to sit back closer to the frame. I used a large adjustable wrench to hold the brackets while I hand-bent them. Bend away from you on the end that bolts to the original horn bracket, bend towards you on the other end. The brackets are hidden behind the horn so they don't have to look pretty. Stebelhorn4.jpg shows the finished project.
padavidj Posted June 22, 2009 #2 Posted June 22, 2009 Looks GGGrrrrrrreat! Dave, aka the Chubby Ape '05 RSTD:thumbsup:
jemorrisonjr Posted June 22, 2009 #3 Posted June 22, 2009 Love mine.... I even installed 2 on other bikes....
StarQ Posted June 22, 2009 Author #4 Posted June 22, 2009 Here is a picture where I traced the outline of the brackets I made with a few notes. Not shown in the picture is the slight bend I made in each bracket to get the horn to sit back closer to the frame. I used a large adjustable wrench to hold the brackets while I hand-bent them. Bend away from you on the end that bolts to the original horn bracket, bend towards you on the other end.
usnmustang Posted June 23, 2009 #5 Posted June 23, 2009 Nice install!! Your gonna love it, especially the first time you wake up a cage. I have 2 on mine and consider it one of the best mods so far. Thanks for sharing your pics and plans.
davecb Posted June 23, 2009 #6 Posted June 23, 2009 If you take the chrome cover off the back side and silicon it on the top it looks even better....
StarQ Posted June 26, 2009 Author #7 Posted June 26, 2009 I took it off and am keeping it as a spare. Good idea with the top chrome, though. If you take the chrome cover off the back side and silicon it on the top it looks even better....
torkk Posted June 28, 2009 #8 Posted June 28, 2009 I had one of those on my little Virago 535. I went a different route with my Royal
