Hello all,
I'm in the process of documenting the install in a PDF document but here are the final pix for the installation.
Based on GeorgeS' comments and feedback from the vendor I may revise the final wiring but all of the wiring is soldered and shrink wrapped at all connectors (including the 1/8" audio connectors) and run through the stock wiring locations.
Due to the fact that there is very limited space I mounted the amp under the right side of the gas tank. All of the cabling is hidden as much as possible (or at least blended) with the speakers inside the windscreen on the bars.
Once mounted the system works and sounds great, I'm very happy with it so far.
Glad to see someone bought these before me. I see you got the plmca 60 version? Have you tried them out on a ride yet? Do you have stock pipes?
Thanks
That looks great. As a new owner, a thousand things I want to do runs through my mind. This is in the top two, which will be a winter project. Thanks for sharing
