i have removed the control unit and resoldered the pins on the circuit board, and the all check out okay. the E-1 code still comes up when i turn on the key to the accessory position.
anyone have this happen before and where is the best place to start?
Cheers, Scott
Guest ReinyRooster
I had the same issue. All I had to do was tighten all connections and clean all around the compressor unit and it stopped.
It took me two times to get it right when I did mine. I missed some pins I guess. I did every pin I could find even if they didnt look bad. Thats over a year and no problems since.
guess what i just read the manual , it said make sure batt. is fully charged , da , i am charging it now and i just got done resolderd the pins , charge your batt. and see if that works
