One of my turn signal seals was letting some water in. Popped a bulb. The water that got in seems to have rusted the bulb in place. Tried some gentler persuasion - then a bit less gentle with some needle nose pliers after the bulb glass broke. Anyone got suggestions on how to loosen this up to get it out without damaging the socket??
Should be easy now that the glass is broken. Use a pair of snap ring pliers
that spread when you sqeeze the handles. This should give you the mechanical
advantage you need. Now you can push in and twist, The bulb should
come out.
Hope this helps you.
