Numb Knuckles Posted September 6, 2007 #1 Posted September 6, 2007 I just bought a 1986 Venture and it has no pressure on the clutch lever - 0. Fluid reservor is full. Master cyl bad? How do I bleed the system? Thanks
Marcarl Posted September 6, 2007 #2 Posted September 6, 2007 Try this thread, it should help you out, if it doesn't type in 'clutch' into the serch button and see if you can find the info you need. http://www.venturerider.org/forum/showthread.php?t=9638&highlight=clutch+slave
Numb Knuckles Posted September 6, 2007 Author #3 Posted September 6, 2007 Thank You! I'm picking the bike up tonight and your info was very helpful.
