I have been working on getting my '89 rebuilt and on the hiway. The problem I have is the tach and lights on the dash have quit working. Could it be one of the relays under the dash or do I have a bigger problem? Engine seems to run fine but the tach, volt meter and lights. Any help would be appreciated.
Chuckles
The following are all powered through the SIGNAL fuse:
Neutral light
Brake lights
Horn
Tachometer
Voltmeter
Temp gauge
If none of them are working I'd look at the fuse.
If I recall correctly there are 3 connectors at the instrument panel, 2 plug into the CMS and the third is on a pigtail and carries all the other stuff. You didn't forget to plug it in did you?
Finally, if everything else is ok check for +12V on the Brown wire the instrument panel plugs into (key on). If you've got 12V there the problem is somewhere in the panel
And, make sure you have a good ground for the dash.
RandyA
Normally yes. These circuits are backwards - they ground through their respective switches/sensors. The common here is the hot (brown lead)
