It's very easy.
There are 2 nuts underneath the front end. You can either use a 10mm open/box end wrench or a 5mm allen wrench to remove the nuts.
Be very careful tightening them back off. Several have had the bolt either pull out of the seat or break off. They just need to be snug.
You might want to look in the classifieds to see if Rick Butler still makes the thumbscrew seat nuts. Makes removal and installation so much easier. You dont know what youre missing unless you have a set of Ricks nuts on your seat.
http://www.m109riders.com/forums/images/smilies/shocked.gif
