ctraylor Posted August 31, 2007 #1 Posted August 31, 2007 I am getting the famous error message on my suspension control. Where is the board located that you have to resoldier. It is not airing up the front shocks although the pressure shows on the screen.
Squeeze Posted August 31, 2007 #2 Posted August 31, 2007 you may look for this ? http://www.venturerider.org/forum/showthread.php?t=493
bongobobny Posted August 31, 2007 #3 Posted August 31, 2007 I would add that, if you aren't used to soldering PC boards, find someone who is to do the work for you...
rhncue Posted August 31, 2007 #4 Posted August 31, 2007 I am getting the famous error message on my suspension control. Where is the board located that you have to resoldier. It is not airing up the front shocks although the pressure shows on the screen. I would check the solder connections as has already been recommended as it is the easiest to do. On the compressor there is a filter that keeps the air dry that go's thru the solenoids to the respective shocks. If either of these three solenoids don't work, because of lack of signal or corrosion, then you will get an error message. Since you are getting a air pressure reading, but no corresponding air transfer, it may mean that these solenoids are not opening as they should. Dick
