Guest weed2 Posted August 30, 2007 #1 Posted August 30, 2007 i get a noise that sounds like a bad tire after 80klicks tire nearly new and wheel bearing new . if i lean forward i dont hear it but if i lean back i hear it . really annoying. has anyone heard of such a noise.
Skid Posted August 30, 2007 #2 Posted August 30, 2007 I had a wild sound out of my 86 VR earlier in the year. I found the front of the drive shaft dry as a bone... problem solved!
Marcarl Posted August 30, 2007 #3 Posted August 30, 2007 I had a wild sound out of my 86 VR earlier in the year. I found the front of the drive shaft dry as a bone... problem solved! That's where I would go looking, or check the splines in the pumpkin, but that should have been done when the tire was off.
Black Owl Posted August 30, 2007 #4 Posted August 30, 2007 Or maybe he is just running ahead of a bunch of 2d gens........
Guest Popeye Posted August 30, 2007 #5 Posted August 30, 2007 If the noise quits when you lean forward, you can be sure the tire isn't the problem. Suspension comes to mind since redistributing weight eliminates the noise. Have you adjusted your CLASS. Also, it would seem a heavy passenger should accentuate the noise & help diagnose the problem.
GeorgeS Posted August 31, 2007 #6 Posted August 31, 2007 When replaceing the Pumpkin, and Axel nuts, Gradually apply torque to the 4 nuts, and the main axel nut, and during the process Tap the assembly with a plastic mallet to relieve any stress. Before beginning the process, rotate the axel, and look for a position with least rotational drag. I do this in a 4 step process of increasing the torque on the 5 nuts. Also, when you get to about 1/2 of the required torque on the nuts, I start the engine, and let it spin the wheel I once had a clicking noise, once each wheel rotation, and this process cured it. Never heard it again. I could hear the noise at about 50MPH going down the road.
