Condor Posted June 3, 2009 #1 Posted June 3, 2009 Since I'm too lazy to go out and check myself I thought I'd pop the question. When removing the rear upper frame assembly, do I need to worry about it being a part of the support holding the frame together, and will it make things go very bad...very quickly if not supporting the chasis. Tom Patterson's old '90 parts bike took a shot to the rear and bent up the trunk mount and frame, and lo-and-behold I actually have another upper... to replace the bent one. The rest of the frame looks pretty straight. I just wanted to make sure that the whole rig doesn't go ka-plooey when I take out that last bolt....
Venturous Randy Posted June 3, 2009 #2 Posted June 3, 2009 (edited) No, just take off the peripheral stuff like bags and wiring and there are four bolts that hold the rear frame on. You don't even have to take the rear wheel assembly off. Not a big job, just several small things. RandyA Edited June 3, 2009 by Venturous Randy
muffinman Posted June 3, 2009 #3 Posted June 3, 2009 No the frame will not go wonky when you remove the rear sub frame Condor. There are 4 bolts holding it together 2 at the front of the seat and 2 at the front of the crash bars (big chrome nut) I have swapped out the MK1 and MK2s before they bolt up the same.Let me know if I can answer any more questions. Jeff
Condor Posted June 3, 2009 Author #4 Posted June 3, 2009 Tanks guys... that's what I needed to know.......
bongobobny Posted June 3, 2009 #5 Posted June 3, 2009 They can be a royal pain to get to line up, though...
Dano Posted June 3, 2009 #6 Posted June 3, 2009 Quit being a lazy butt Jack, and just get out there and get to bein' busy! Dan
Condor Posted June 4, 2009 Author #7 Posted June 4, 2009 Quit being a lazy butt Jack, and just get out there and get to bein' busy! Dan I yam...I yam.... and it is a PITA like Bob said. But I'm getting there...
