Col Chubbs Posted June 3, 2009 #1 Posted June 3, 2009 Friends, I am knew to the forum and as I have looked around I cannot find the answer to the problem that I am having. I drive a 96 Royal Star. I am having a gas leak from a hose that comes down the left side of the bike. It is a hose that comes down right under the choke pull. It goes down into the area between the cylinders and ends at a rectangle bracket. On the other side of this bracket there is nothing, just the hole of the hose that is connected to the hose. This is where the leak is. I figure this should be an easy fix, but looking at the service manual I cannot find what the hose is nor what should be on the other side of the bracket/guide.
Eck Posted June 3, 2009 #2 Posted June 3, 2009 Friends, I am having a gas leak from a hose that comes down the left side of the bike. It is a hose that comes down right under the choke pull. It goes down into the area between the cylinders and ends at a rectangle bracket. On the other side of this bracket there is nothing, just the hole of the hose that is connected to the hose. This is where the leak is. Possible stuck float in carbs...causing gas to run out in over flow tube.???? Suggest you could try pouring in one can of Sea foam into the gas tank then fill her up and ride it close to empty, then fill it up again with only gas and see if it still leaks......
Col Chubbs Posted June 3, 2009 Author #3 Posted June 3, 2009 Sorry about the run-on sentence that made no sense at all anyway. The hose is the Air Vent Hose if that gives anyone a better idea of what could be wrong.
M61A1MECH Posted June 3, 2009 #4 Posted June 3, 2009 Yep that is the overflow, float is stuck or the needle valve has trash in it., Try shutting of the pet cock and running the carbs dry, then a good dose of seafoam.
Col Chubbs Posted June 5, 2009 Author #5 Posted June 5, 2009 Thanks everyone, the seafoam took about 15 minutes to work, it was amazing. I had never heard of the stuff before and am sold on it.
