It was my impression that the 1stGen clutch covers were all the same from 83-93 1200/1300. Then ran acrossed this item on Ebay. CLUTCH I can't believe that yama-mama changed the cover in any way, but here's a seller that says the one he just bought on Ebay doesn't fit. Whatcha think???
Yep, I seem to recall this coming up a while ago. Read the question someone asked. The 1200's ('83-'85) have the clutch that uses 6 coil springs. The 1300's ('86-'93) uses a diaphram clutch spring. The outline of the clutch cover is the same, but the depth is slightly different.
Wow!! Doesn't make sense that they would have changed it, but here's another piece of Venture lore we need to be aware of. I guess if anyone plans of replacing their clutch cover they need to make sure the replacement comes off a 'fits all' 1300 engine.......
