Guest seuadr
So, you guys are pretty knowledgeable, i thought i would ask here.
if this is too far off topic, feel free to delete it, and i appoligize in advance.
I got a free john deere sx95 mower, with a 38'' deck. the problem i have is, the PO took it apart for some unknown reason because it didn't run. well, it didn't run because he didn't have some connectors actually.. you know.. connected.
so anyhow. the problem is, I don't know how to route the new belt i have. it's on there how it seems to need to be, but the tensioner isn't functioning properly or something,because it's not tight enough. i've looked at JDparts.com but the overall setup is still sort of vague.
I was hoping somone here might have this mower that would be willing to take a pic if the tensoner(s) setup? i would be eternally grateful.
thanks in advance.
- Jared
I'm sure one of the guys on here can help you out with this problem. Sorry I can't help I just start our mower and go, I do check the gas. Good luck.
Margaret
im not sure on that model but i have a 316 and the belt tensioner on it is on the front of the tractor with a knob ou adjust to tighten or losen. you might give a call to your local dealer or stop by they should be glad to help you. good luck
