WilCruise Posted May 25, 2009 #1 Posted May 25, 2009 I'll be at Americade on the afternoon of June 2nd and leaving PM of June 4th to head down to Don's. I'm stopping in Buffalo to pick up the Mrs. at the airport there (AM of the 5th) along the way. I'll also be doing the covered bridge run on Wed. If anyone wants to catch up while there - or head down towards OH together on the 4th leave a post here.
bongobobny Posted May 25, 2009 #2 Posted May 25, 2009 Hey pal, give a call and stop in if you're going to be that close!! We are about 45 minutes SE of the airport. We will be leaving for MD on Friday afternoon and staying at the Inn. You are welcome to ride along if it fits your plans I plan on leaving work at noo n Friday which is even closer to the airport. Give a call!!
WilCruise Posted May 30, 2009 Author #3 Posted May 30, 2009 OK Bob, Thanks! I'll check in with you when I have timing nailed down a bit better.
