Jethroish Posted May 24, 2009 #1 Posted May 24, 2009 (edited) Went for a nice ride today. Daughter rode with me, wife on her bike and the neighbors joined us. Had to get on the brakes hard once and noticed the pedal pulsing under my foot so I tried to stay off the rear brake. Got home and removed the rear caliper. The inside pad was down to the metal. 23,000 on these original pads. Is that good, bad, average? So of course this has to occur after all dealers are closed, on a holiday weekend. can't do anything until Tuesday. I hope it rains for the next few days. Edited May 24, 2009 by Jethroish
BuddyRich Posted May 24, 2009 #2 Posted May 24, 2009 I usually only get about 8k to a set of rear pads.
juggler Posted May 24, 2009 #4 Posted May 24, 2009 Mariner Fan said: Why would the rear pads go out so fast? I can give two reason. 1. the natural tendency to use more rear brake than we should 2. there is only one rotor on the rear so it has to work more to stop than the dual rotor front breaks.
BuddyRich Posted May 24, 2009 #5 Posted May 24, 2009 If your using the techniques from Ride Like a Pro your gonna be using the rear brake a lot at slow speeds. That eats up the rear pads.
Jethroish Posted May 24, 2009 Author #6 Posted May 24, 2009 Pulled the front pads. they are still about 50%. Did not realize I used the rear brake that much, but I am guessing that 23,000 miles is pretty good.
juggler Posted May 24, 2009 #7 Posted May 24, 2009 Jethroish said: Pulled the front pads. they are still about 50%. Did not realize I used the rear brake that much, but I am guessing that 23,000 miles is pretty good. That's not bad for mileage. And they are easy enough to replace.
Mariner Fan Posted May 24, 2009 #8 Posted May 24, 2009 BuddyRich said: If your using the techniques from Ride Like a Pro your gonna be using the rear brake a lot at slow speeds. That eats up the rear pads. I do use my rear brakes to scrub off speed in corners. Just surprised they will wear out so fast.
