fixit3546 Posted August 26, 2007 #1 Posted August 26, 2007 I knew that i needed a new back tire and it should have been here last week but somehow over night shipping turned into 5 days, enough about that. Like i said, i knew the tire was slick. I looked at it every day to make sure it was still just slick and not worse. The problem is that with the bumper and all the trim, it is difficult to see the tire without a close inspection. I could only see about 6 inches of the tread through this hole that is suppose to have a rubber insert in it. Everytime i looked at it, I saw a slick tire; but it still had rubber there. Well, I got my new tire in finally. Tuesday. When i looked at the tire I saw what you see in the picture. It is only half of the tire. the other half still has rubber and is what i was looking at. I had just ridden this home, about a 25 mile trip, Making about 70 MPH on Hwy 49. And it was hot...............All i can say is thank you Jesus!!! They say He watches over Old Folks and fools. I guess that means i got double protection. Now, go look at your back tire, and look at it good. BTW, The other picture is how i got the tire off. With all the dress items it is almost impossible to get the tire out from under the bike with it just on the center stand. This time i put the kick stand down on a 2x4 and set me floor jack under the pivot point of the center stand. This allowed me to raise and tilt the bike allowing easier removal of the tire. It worked almost flawlessly. The jack should have been placed further back though. It was almost at the balance point. When i put the tire back on, the bike almost tilted back and it tried to spin aroung at the same time.
Mean Dog Posted August 26, 2007 #2 Posted August 26, 2007 You and Kbran must be related....LOL. that is the way his tire looked while we were in Vogel!. I sure am happy for you that it did not blow out. Sometimes the Lord is our copilot James. Be careful out there brother. Mark
GeorgeS Posted August 26, 2007 #3 Posted August 26, 2007 Don't Ever do that again !!!!!!! Bye the way, could you cut a section out of the Old tire, and post a good close up of the tread thickness ?? Is that a D-404 ???
fixit3546 Posted August 26, 2007 Author #4 Posted August 26, 2007 I'll see what i can do George. It is a Maxxis Classic. It is the only wide white wall i have found, so far, that has the right size front and rear. I'm sure they are out there;but i havent found them.
V7Goose Posted August 26, 2007 #5 Posted August 26, 2007 Hey man, your are definitely a lucky man! I have made the exact same mistake, but the worst I got was the first chord layer just beginning to show - you wore COMPLETELY THROUGH TWO LAYERS OF CHORD, and maybe three! It's hard to tell from that picture, but it looks like the third layer is worn all the way through also. WOW! Man, the rest of that carcass had to be getting thin there, especially if it was only a 3-ply tire. One last thought for you - check your tire balancing carefully - for one spot to be that badly worn through while the other half of the tire didn't show the cord at all suggests that it was way out of balance. Goose
fixit3546 Posted August 27, 2007 Author #7 Posted August 27, 2007 V7Goose said: Hey man, your are definitely a lucky man! I have made the exact same mistake, but the worst I got was the first chord layer just beginning to show - you wore COMPLETELY THROUGH TWO LAYERS OF CHORD, and maybe three! It's hard to tell from that picture, but it looks like the third layer is worn all the way through also. WOW! Man, the rest of that carcass had to be getting thin there, especially if it was only a 3-ply tire. One last thought for you - check your tire balancing carefully - for one spot to be that badly worn through while the other half of the tire didn't show the cord at all suggests that it was way out of balance. Goose Your right, 3 belts and pegscraper, I'm not sure because of a speedometer failure, but i'm guessing only 6-7k miles. The Maxxis classic is not the best tire for mileage(on mine anyway) But i have trouble finding the right size in a wide white wall that has a matching front and rear as far as the size. The 140/90/18 is $104.00 (locally)so i can afford it and not loose much in the long run.
pegscraper Posted August 27, 2007 #8 Posted August 27, 2007 That's what I keep hearing about that brand. Less money to get up front, but mileage is lousy. More expensive in the long run. But sometimes there is no other choice.
Yammer Dan Posted August 27, 2007 #9 Posted August 27, 2007 pegscraper said: How many miles did you get on that tire? ALL HE COULD!!
fixit3546 Posted August 27, 2007 Author #10 Posted August 27, 2007 Yammer Dan said: ALL HE COULD!! And then a couple more.......................
cmiles3 Posted August 27, 2007 #11 Posted August 27, 2007 You were lucky twice, if that's the way you jacked up your bike to remove the wheel.
fixit3546 Posted August 28, 2007 Author #12 Posted August 28, 2007 cmiles3 said: You were lucky twice, if that's the way you jacked up your bike to remove the wheel. This is not the first time, wont be the last time. The first time was on a honda shadow with no center stand. It worked out very well.
