Scooter Posted May 21, 2009 Posted May 21, 2009 I'm going to order Progressive Springs for the front end on my '83 VR. I noticed that there are different weights of springs, so I'm not sure which to order. I'm a big guy and often ride two up, so I'm assuming that I should get the heaviest that I can get. Any recommendations?
GeorgeS Posted May 21, 2009 Posted May 21, 2009 I'm going to order Progressive Springs for the front end on my '83 VR. I noticed that there are different weights of springs, so I'm not sure which to order. I'm a big guy and often ride two up, so I'm assuming that I should get the heaviest that I can get. Any recommendations? First I heard of that?? I thought there was just one Progressive Part Number, for the Ventures. But ?????
RedRocket Posted May 21, 2009 Posted May 21, 2009 I recently put some in my 88. There was only one part # available on the Progressive website.
Rocket Posted May 21, 2009 Posted May 21, 2009 I'm going to order Progressive Springs for the front end on my '83 VR. I noticed that there are different weights of springs, so I'm not sure which to order. I'm a big guy and often ride two up, so I'm assuming that I should get the heaviest that I can get. Any recommendations? If you are getting the Progressive Suspenson springs, their part # is 11-1112 & that is for all 1st gens. Some members run without any air in the front, after installation, I had installed Friesman1's without the preload spacers, so his new taller windshield will clear his "garage" opening & he still was not using air in the forks, as of last weekend.
Scooter Posted May 21, 2009 Author Posted May 21, 2009 If you are getting the Progressive Suspenson springs, their part # is 11-1112 & that is for all 1st gens. Some members run without any air in the front, after installation, I had installed Friesman1's without the preload spacers, so his new taller windshield will clear his "garage" opening & he still was not using air in the forks, as of last weekend. Thanks, I thought that was the part number, but wasn't sure. I've located them at Mawonline.com for $65.95 Thanks
Scooter Posted May 21, 2009 Author Posted May 21, 2009 First I heard of that?? I thought there was just one Progressive Part Number, for the Ventures. But ????? Yeah, I was off a bit on where I was looking and made the assumption that it applied to my bike. Thanks!
Condor Posted May 21, 2009 Posted May 21, 2009 Progressives only have one spring for the 1stGens, but Racetech lists several different springs weights. I think there's one or two other suspension sites that also make springs to match the weight of the rider???
Pappa Bear Posted May 21, 2009 Posted May 21, 2009 I put progressives in my 89 about a month ago, still not sure if I like them or not,feel pretty stiff even running with 0 air. Sure did raise the front end up though, and making it hard on this short guy to reach the ground!!!
friesman Posted May 21, 2009 Posted May 21, 2009 When Rocket put the new progressives in mine over the winter, he didnt include the preload spacers as we agreed it would make the bike too high for me to ride because of the saddlemens seat on it, and because I needed to get the scoot into my trailer at night and the xxxl clearview windhield might not clear the door at top. The progressives without the spacers still raise me up about an inch with me on it (about 300lbs) and it never bottoms out even with out any air in the forks. the improvement in the ride is amazing!!! its a great improvement!!!!!! Brian
Scooter Posted May 21, 2009 Author Posted May 21, 2009 This all sounds very good. I took my bike out for a ride the other day after doing quite a bit of work on all parts of the bike, and I had forgotten how bad the thing was bottoming out. I am around 290#'s and 6'5'' so the extra height might not bother me. But by leaving the spacer out it should be pretty easy getting the plugs in. With the old springs, the plugs went in with hardly any effort at all. Is it hard to get the plugs in with the progressive springs with the spacer?
Rocket Posted May 21, 2009 Posted May 21, 2009 But by leaving the spacer out it should be pretty easy getting the plugs in. With the old springs, the plugs went in with hardly any effort at all. Is it hard to get the plugs in with the progressive springs with the spacer? With the spacer in, yes, it is basically a 2 person job to get that last bit of downward pressure needed. This is with me standing on the foot pegs & pressing down on a 1/2" drive "speed handle" attached to the 17mm allen head socket. Without the spacer, it is very easy to do it solo.
Pappa Bear Posted May 22, 2009 Posted May 22, 2009 When I put mine in I cut the spacer in half, how much do ya think it would lower the front by totally removing the spacer? I do need to get it lower or buy boots with thicker soles!!!!!
greg_in_london Posted May 25, 2009 Posted May 25, 2009 I used Sonic Springs, who had a choice of spring weights and was very happy with the result right from the outset. Their spacer was a heavy walled plastic tube that I could cut to my desired length - works !
bongobobny Posted May 25, 2009 Posted May 25, 2009 **Sigh** Some day I'll get to try out my new Progressives, along with the new brakes, SS lines, E3's etc...
RedRocket Posted May 25, 2009 Posted May 25, 2009 I was surprised that I didn't have much difficulty with my spacers. I jacked the bike up from under the engine, so the forks were on full extenstion.
Scooter Posted May 25, 2009 Author Posted May 25, 2009 I was surprised that I didn't have much difficulty with my spacers. I jacked the bike up from under the engine, so the forks were on full extenstion. That's how I plan on swapping my springs when they show up.
RedRocket Posted May 25, 2009 Posted May 25, 2009 That's how I plan on swapping my springs when they show up. Sometimes there is merit to reading the included instructions.
Scooter Posted June 12, 2009 Author Posted June 12, 2009 Got my Progressive Springs installed and test drove it this evening. Amazing what a difference they make. I used the entire pvc bushing witn no air in the forks and they were perfect.
PBJ Posted June 12, 2009 Posted June 12, 2009 Did you guys all change the oil at the same time you changed the springs? You don't have to remove the whole fork right just the top caps? My bottoms out too and the air pump won't pump the front fork anyway. I have a bike jackd and it seems that elevating the front wheel to fully extend the fork makes it easier is that right? I was going to have Progressive do it at Americade but ran low on money.
Scooter Posted June 12, 2009 Author Posted June 12, 2009 Did you guys all change the oil at the same time you changed the springs? You don't have to remove the whole fork right just the top caps? My bottoms out too and the air pump won't pump the front fork anyway. I have a bike jackd and it seems that elevating the front wheel to fully extend the fork makes it easier is that right? I was going to have Progressive do it at Americade but ran low on money. I replaced the fork oil when I swapped out the springs, though I put in 1 oz less in each fork due to more of the displacement made by the bigger Progressive spring. You do not have to remove the forks. Go to the tech library and follow the steps to do this, it's pretty straight forward. Remember to jack up and support the front of the bike, getting the front tire off of the ground, or when you pull out the top plugs, you will be making full use of your vocabulary.
Scooter Posted June 12, 2009 Author Posted June 12, 2009 Here's the link to the tech article on swapping the fork springs. http://www.venturerider.org/forum/showthread.php?t=505
RedRocket Posted June 13, 2009 Posted June 13, 2009 Did you guys all change the oil at the same time you changed the springs? You don't have to remove the whole fork right just the top caps? My bottoms out too and the air pump won't pump the front fork anyway. I have a bike jackd and it seems that elevating the front wheel to fully extend the fork makes it easier is that right? I was going to have Progressive do it at Americade but ran low on money. You've got the right idea. There are drain screws on the bottoms of the fork legs. If you don't have easy access to fork oil, or don't want to spend the $ you can use transmission fluid. The springs be such an improvement that I think any differences in oils would be minscule.
