Jrichard Posted May 19, 2009 #1 Posted May 19, 2009 Has anyone done a cross-reference on the starter{solenoid} relay------other than going to the Yamaha dealer------I thunk that on my 92 the starter relay has seen better days!------it only clicks--------the battery is fully charged.
Rottdoglover Posted May 20, 2009 #2 Posted May 20, 2009 Short across the 2 main post on solenoid to make sure it's not a bad cable. If you are VERY careful, you can take them apart and clean the contacts. Just watch for tiny wire connections. I've done this on several with good results. Look at it this way; If it's broke you can't hurt it any more. Good luck. IF you have room, a solenoid off a old Ford works.
Jrichard Posted May 20, 2009 Author #3 Posted May 20, 2009 Short across the 2 main post on solenoid to make sure it's not a bad cable. If you are VERY careful, you can take them apart and clean the contacts. Just watch for tiny wire connections. I've done this on several with good results. Look at it this way; If it's broke you can't hurt it any more. Good luck. IF you have room, a solenoid off a old Ford works. What yr. Ford?-------------car or pick-up!
GeorgeS Posted May 20, 2009 #4 Posted May 20, 2009 most any of the older car relays would work. some small forign car maby. Just try to find the smallest one an auto parts store might have. Mounting space would be the main problem.
gscbertrand Posted May 20, 2009 #5 Posted May 20, 2009 They also make aftermarket solinoids for motorcycles. I just bought 1 for a XS400 yamaha twin for $69.98 CDN it comes with the correct plug ends and a new rubber holdr.
Rottdoglover Posted May 20, 2009 #6 Posted May 20, 2009 What yr. Ford?-------------car or pick-up! Like GeorgeS states, about any will work. Even lawn mower ones. Just get the smallest posssible. As long as you get the + cable and start wire to it then get back to starter, it will work. Even if you have to move location and add longer cables.
skydoc_17 Posted May 20, 2009 #7 Posted May 20, 2009 Hey J, There is one on Ebay right now, the item # 350199185240 It's $10.00 and $5.00 to ship. The 1983-1985 VR solinoid is different, this one is for your MKII1300 VR and looks to be in great shape! I have done business with these people before, they are good people to deal with. Hope this helps, Earl
Jrichard Posted May 20, 2009 Author #8 Posted May 20, 2009 .Pulled both the pos. and neg. cables{both had places that were worn} replaced the neg. and could not get the pos, one off of the starter -------them Japs must have really small hands------was able to wrap the pos. cable> over the yrs both cables had RUBBED against the frame and were causing a short!---------Soooo hopefully the prob. is rectified!!--------THANK you guys fer ya;lls Knowledge and expertise------:usa:MEMORIAL DAY is approaching -------ROLLING THUNDER is headed East to D.C.------Please REMEMBER all of our VETS-------from all wars-----and the ultimate sacrifice THEY made-------carry-on---------
GeorgeS Posted May 21, 2009 #9 Posted May 21, 2009 However, you still might want to find a spare Solinoid and keep it at the Ready !!!
