Guest Nevada Max Posted May 19, 2009 #1 Posted May 19, 2009 Could some one steer me to where I can b y these brackets for this modification. I have RK slip ons! I tried the clasified . Thanks in advance Nevada Max
gunboat Posted May 19, 2009 #2 Posted May 19, 2009 squidley had been making some but i don't think he does that anymore. but maybe he'll chime in and advise you where you can find some. best reguards don c.
kbran Posted May 19, 2009 #3 Posted May 19, 2009 Could some one steer me to where I can b y these brackets for this modification. I have RK slip ons! I tried the clasified . Thanks in advance Nevada Max There on page 2 under 2nd gen parts & acc http://www.venturerider.org/classifieds/showcat.php/cat/7/page/2
ragamuffin Posted May 19, 2009 #4 Posted May 19, 2009 If you give me three or four days I will make you a set, I use quarter inch aluminum which looks great and has worked very well for me. If you want me to fab a couple for you just shoot me an adress- tj
AKRefugee Posted May 19, 2009 #5 Posted May 19, 2009 (edited) There on page 2 under 2nd gen parts & acc http://www.venturerider.org/classifieds/showcat.php/cat/7/page/2 Got mine from hilliss and let me tell you they are great. Ordered late evening on Thursday and had them in hand on Monday. Great quality, great price and every bolt, nut and washer you need. The instructions are so clear cut, and pictures on how to do it were so concise, even I was able to do the job. Also I found exact clamp I needed at www.masclassics.com/index.htm V twin part number 31-9920. Got those in 5 days. When putting them on I found using 200 grit sand paper on end of the header pipe to clean off the existing exhaust grime and spraying it with PAM (so no smell when it burned off) helped immensely. Needed a helper when putting the HD pipes on. One to hold it in place and one to beat them on. I used a 2x4 at end of pipe and a mallet to the 2x4 and caused no damage. The sound great without being loud. Hope this helps. Edited May 19, 2009 by AKRefugee
Leadwolf56 Posted May 19, 2009 #6 Posted May 19, 2009 Needed a helper when putting the HD pipes on. One to hold it in place and one to beat them on. I used a 2x4 at end of pipe and a mallet to the 2x4 and caused no damage. The sound great without being loud. Hope this helps. If you use a screwdriver in the slots on the inlet of the HD pipes you can open them up a little bit and you won't have to beat them on. Mine slipped on pretty easy after I did this.
