NCReb Posted May 18, 2009 #1 Posted May 18, 2009 Hi every one. We ride two up on a 07 Venture and my wife would like to have some arm rest, anyone have a resource? Also how do y'all get those maps that display the States you've traveled? Thanks for any help
mike_kelly_68 Posted May 18, 2009 #2 Posted May 18, 2009 Some have purchased rests from Diamond R. I believe there is a post in the vendors forum section. Maps, I can't remember.
kbran Posted May 18, 2009 #3 Posted May 18, 2009 (edited) This http://www.diamondraccessories.com/ is the only place I know to buy armrest. For your signature map go here http://www.epgsoft.com/index.html. Create your map and save it on your computer as a small map. Go to user cp on this site and go to settings and options then click on edit signature. Below the text box you will see upload picture, upload from computer and save your signatrue. Edited May 18, 2009 by kbran
Sylvester Posted May 18, 2009 #5 Posted May 18, 2009 Do yourself a favor and instead of using the Diamond R screws to secure the arm rests, drill throught the passenger hand hold from the bottom with a 1/4" bit. Then use a 1/4 carriage bolt from the top with a nylon lock nut at the bottom to affix the arm rest. You will never have to mess with them again.
