Marktheshark Posted May 18, 2009 Posted May 18, 2009 I have a 1983 Venture motorcycle. I need to replace the anti-dives on it and was wondering if the models from 1983 1984 and 1985 are all the same part number for the anti-dives? I want to be sure to order the correct anti-dive. Also, do you know where I could buy a pair of used anti-dives for this bike? Any information you can give me is much appreciated. Thanks. Marktheshark
Condor Posted May 19, 2009 Posted May 19, 2009 I have a 1983 Venture motorcycle. I need to replace the anti-dives on it and was wondering if the models from 1983 1984 and 1985 are all the same part number for the anti-dives? I want to be sure to order the correct anti-dive. Also, do you know where I could buy a pair of used anti-dives for this bike? Any information you can give me is much appreciated. Thanks. Marktheshark Try Bongobobny on this board. He may have a set. Are yours leaking??
Captainkirk Posted May 30, 2009 Posted May 30, 2009 I have a 1983 Venture motorcycle. I need to replace the anti-dives on it and was wondering if the models from 1983 1984 and 1985 are all the same part number for the anti-dives? I want to be sure to order the correct anti-dive. Also, do you know where I could buy a pair of used anti-dives for this bike? Any information you can give me is much appreciated. Thanks. Marktheshark Mark.... I have a set of antidives on the forks I have for sale; I would consider separating. These are off an '84 Royale. I will cross-check P/Ns and get back to you.....
bongobobny Posted May 30, 2009 Posted May 30, 2009 My set of MK1 Anti Dives just got shipped out this week! However, I did notice something when I had them off, the mounting is identical to the MK2 electric anti dive solenoids!! You can switch over to electrics and eliminate the load on the brake system which should improve the brakes on the ffront, something that is sorely needed on the MK1's...
Condor Posted May 30, 2009 Posted May 30, 2009 My set of MK1 Anti Dives just got shipped out this week! However, I did notice something when I had them off, the mounting is identical to the MK2 electric anti dive solenoids!! You can switch over to electrics and eliminate the load on the brake system which should improve the brakes on the ffront, something that is sorely needed on the MK1's... Now that's interesting.....
