ediddy Posted August 24, 2007 #1 Posted August 24, 2007 I just ordered a venture dad hitch. Roy said to use a standard boat trailer 5 pin flat rubber connector wiring kit that you can get from most auto parts stores. A friend of mine has a trailer he pulls with his goldwing and said I can use it anytime to get the feel of pulling a trailer before I buy one. I thought this is great. My wife and I are going on a trip next week so this will be a good time to pull a trailer. But my friend says he has a 4 pin connector with a 5th wire added. I also saw on a thread this morning on the hopkins hoppy trailer kit which it says is a 4-way flat connector. What should I do to wire my venture for a trailer. I am confused, however it doesn't take much to confuse me. Thanks.
utadventure Posted August 24, 2007 #2 Posted August 24, 2007 The trailer you bought needs the 5-pin flat connector - that's what I would install. Then if you want to pull your friends trailer, either go during the day with low traffic, without attaching the wiring or temporarily connect a 4-pin. Then you can switch it out for your 5-pin. Lastly, you could wire your 5-pin and then make a patch cable to go from 5-pin to the 4-pin. Dave
nelsontoddpa Posted August 24, 2007 #3 Posted August 24, 2007 I went with the 4 pin flat with the modulator recommended by Freebird in his excellent tech article. Most of the motorcycle trailers I have seen have the 4 pin connector as well (including my friend's trailer that I get to borrow every now and then). Also, when I ordered my golf club carrier from Als custom motorcycles I simply had him put on a 4 pin set up which works perfectly running lights and all. Incidentally, my friend has a honda shadow, tried to put on the 5 pin set up from the goldwing, and we couldn't get it to work for anything including adapters. He eventually went to the local U-haul dealer and they had a isolator/modulator that is nearly identical to the one recommended by Freebird and it works perfectly. Hope this helps Todd
ediddy Posted August 24, 2007 Author #4 Posted August 24, 2007 Thanks for the replies. How do I find the tech article by Freebird? I've looked and can't find. Thanks
cortalan Posted August 24, 2007 #5 Posted August 24, 2007 my trailer has a 4 pin wiring harness as well. I went to ARNOLDS AUTO PARTS and bought a 5 to 4 wiring harness. 5 wires for the bike...............4 for the trailer. Works great.
Christo Posted August 25, 2007 #6 Posted August 25, 2007 I went with the 4 pin flat with the modulator recommended by Freebird in his excellent tech article. Where is this article, I can't find it either.
sarges46 Posted August 25, 2007 #7 Posted August 25, 2007 Here ya go fellas http://venturerider.org/forum/showthread.php?t=503
Mean Dog Posted August 26, 2007 #8 Posted August 26, 2007 Thanks for the replies. How do I find the tech article by Freebird? I've looked and can't find. Thanks ediddy, It will depend on which tail light system your friend has on his trailer! If it has separate turn signals then you will need the 5 wire flat and no converter. If it uses the brake lights as turn signals you will need the converter. I see you have not bought you a trailer as of yet so you will have to wire to his trailer needs. Why did your friend add the 5th wire and what is it used for? These are the questions you will need to know before wiring your bike to it. My first trailer was a 4 wire and I needed a converter and now the trailer I have is a 5 wire and I just hot wired behind the license plate since it has separate amber turn signals just like the bike! Dog
Christo Posted September 24, 2007 #9 Posted September 24, 2007 Ok, I am waiting on my cargo trailer: See picts. It is currently a 4 wire. I am going to add amber LED 6" oval turns to it, since it originally comes with only red LED 6" ovals for the rear. I will wire these up and add them to the existing wiring set up. I bought a Khrome Werks receiver hitch for my '99 RSV. It comes with a round 5 wire hook up. I have replaced my signals/turns, brake lights, and running lights, with LED's from custom dynamics. So the only incandescent bulbs on my bike are the head light and the driving lights. My questions: 1. Do I need an isolator? If the trailer and the bike are primarily LED. 2. If I do need an isolator, which one should i get? I was able to find these three, are there more? Out of these, which one is best? Why? http://www.motoleather.com/untrisha1.html http://electricalconnection.com/wire-harnesses/hrns-trailer.htm http://www.wingworx.com/index.asp?PageAction=VIEWPROD&ProdID=176 3. Are there inline adapters for adding trailer wiring for the RSV's? I saw some for the 1800 GW's and for HD's. Any additional thoughts, feedback, suggestions? TIA for all your help and advice.
Christo Posted September 24, 2007 #10 Posted September 24, 2007 Anyone know of a source where we could purchase the male and female plastic connectors that are found under the seats for the rear to front wiring harness? I am thinking about making an inline harness for trailer hook-ups. Anyone want to help me in my quest?
Freebird Posted September 25, 2007 #11 Posted September 25, 2007 I'm not sure but you might try here. http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0D2E5E3B996801008DAD082+M37+ENG
Christo Posted September 25, 2007 #12 Posted September 25, 2007 I'm not sure but you might try here. http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0D2E5E3B996801008DAD082+M37+ENG I get an error, can't get to the link.... will keep trying, thanks Freebird!
Freebird Posted September 25, 2007 #13 Posted September 25, 2007 Sorry about that. Here is the main link. Then click on "Products" and then "MultiPin Connectors". http://waytekwire.com/
Mikealiasmike Posted September 25, 2007 #14 Posted September 25, 2007 After getting my trailer wired at the VIP I came home and purchased this. It will stop feedback of electricity from the trailer to the scooter. Winter project I guess. Ride safe and God Bless. Mike http://cgi.ebay.com/ebaymotors/TRAILER-WIRING-ISOLATOR-CONVERTER-VEHICLE-CIRCUIT-SAVER_W0QQcmdZViewItemQQcategoryZ50072QQihZ007QQitemZ170151681188QQtcZphoto
Christo Posted September 25, 2007 #15 Posted September 25, 2007 After getting my trailer wired at the VIP I came home and purchased this. It will stop feedback of electricity from the trailer to the scooter. Winter project I guess. Ride safe and God Bless. Mike http://cgi.ebay.com/ebaymotors/TRAILER-WIRING-ISOLATOR-CONVERTER-VEHICLE-CIRCUIT-SAVER_W0QQcmdZViewItemQQcategoryZ50072QQihZ007QQitemZ170151681188QQtcZphoto Thanks, but this is a converter & isolator. I am just looking for an isolator, and I am still wondering if it is necessary to even bother with an isolator.
Christo Posted September 25, 2007 #16 Posted September 25, 2007 Sorry about that. Here is the main link. Then click on "Products" and then "MultiPin Connectors". http://waytekwire.com/ Thanks Freebird! I will experiment and see what I can come up with for an inline harness.
Keitho Posted November 8, 2007 #17 Posted November 8, 2007 Hey Christo, did you go ahead with the "Isolation unit" or did you skip it? If you went ahead with it were did you buy it from? Keith.
Christo Posted November 8, 2007 #18 Posted November 8, 2007 Hey Christo, did you go ahead with the "Isolation unit" or did you skip it? If you went ahead with it were did you buy it from? Keith. Keith, I skipped it. The trailer is all LED.
