Carbon_One Posted August 24, 2007 #1 Posted August 24, 2007 Ok folks who knows what the gear ratio is for the 2nd gen differentials? What's the 1st gen and V-max ratios too for that matter? Larry
flb_78 Posted August 24, 2007 #2 Posted August 24, 2007 everything you could want to know about the gears is right here... http://www.venturerider.org/forum/showthread.php?t=12800
pegscraper Posted August 24, 2007 #3 Posted August 24, 2007 Yes, it's probably somewhere in those seven pages. For a little easier to find answer - the V Max has a 9/33, and all Ventures are 10/33.
Carbon_One Posted August 24, 2007 Author #4 Posted August 24, 2007 Thanks fib & pegscraper. I did find the info after wading thru the posts. Coverting those numbers make the RSV a 3.33/1 ratio and the V-Max a 3.67/1 ratio which is what I was looking for. Larry
