Midrsv Posted May 15, 2009 Posted May 15, 2009 For the last week I've been on vacation and have done quite a bit of riding and I have been observing the water temperature guage that I recently installed. The temperature doesn't seem to be very stable. Sometimes when cruising 60 mph it will hold at 185 and a while later it will be at 200, cruise on a while longer and it will drop back to 190. At first I just thought it was the thermostat cycling but it may hold the temperatures for 30 minutes or more. In the cars and trucks that I have owned the temperature is always very stable at cruising speeds. Have any of you with guages noticed this type of temperature swings? My guage is an electrical guage. Dennis
gibvel Posted May 15, 2009 Posted May 15, 2009 Are the times when it gets hotter times when the engine is forced to work harder, like, stronger winds, up hill, dragging your feet... ? I know I've seen the temp gauge in my car go up and down (digital gauge) when going uphill, on long stretches, or with a strong wind.
SilvrT Posted May 15, 2009 Posted May 15, 2009 Mine is pretty constant at around 210 ... but mine isn't electrical... maybe the electrical ones are a bit more sensitive to the temp swings at the engine whereas the kind I have might not be. Personally I wouldn't be too concerned about it as long as the readings don't go too far beyond 200-210.
Guest Lightnen Posted May 15, 2009 Posted May 15, 2009 For the last week I've been on vacation and have done quite a bit of riding and I have been observing the water temperature guage that I recently installed. The temperature doesn't seem to be very stable. Sometimes when cruising 60 mph it will hold at 185 and a while later it will be at 200, cruise on a while longer and it will drop back to 190. At first I just thought it was the thermostat cycling but it may hold the temperatures for 30 minutes or more. In the cars and trucks that I have owned the temperature is always very stable at cruising speeds. Have any of you with guages noticed this type of temperature swings? My guage is an electrical guage. Dennis I installed a machcanical guage few months ago as well and on my 06 RSV it will go as high as 220 F. BUT as long as it don't go higher I don't think there is anything to worry about. Guages will vary and not two will read the same unless you install a very very expensive one..
Ponch Posted May 15, 2009 Posted May 15, 2009 When in the west Tx mountains a couple a weeks ago the ambient temp was 101°, the water temp was holding steady at 220°. Normally averages 205°.
Midrsv Posted May 15, 2009 Author Posted May 15, 2009 I haven't been too concerned about the variation in readings. The only time it gets to 210 is in stop and go city driving. All other times the temps stay between 185 and 200. It just seemed to fluctuate more than I expected for steady state level riding. Dennis
Monsta Posted May 15, 2009 Posted May 15, 2009 In the cars and trucks that I have owned the temperature is always very stable at cruising speeds. Most cars and trucks have glorified idiot lights acting as gauges. These move to a preset level when temperatures are within a typical range and stay there. One exception (off the top of my head) are the gauges in Chevy trucks. They are real gauges and one of the things I prefer over my Ford truck that has fake gauges. Some of you who are always over 200° need to check out for airflow obstructions or coolant condition. Cruising should have temp values of
tommycole Posted June 1, 2009 Posted June 1, 2009 Would somebody tell me which head has a plug for the sending unit? Thanks Tommy Cole
V7Goose Posted June 1, 2009 Posted June 1, 2009 Some of you who are always over 200° need to check out for airflow obstructions or coolant condition. Cruising should have temp values of Not so. Standard operating temperature for the RSV is 210 F. I have verified this with an infrared thermometer on the head right next to the sending unit. That has been true for both my 2005 and the 2007 I owned. Additional information to support that is the fact the shop manual states the thermostat does not reach full open position until 203 F. Goose
Midrsv Posted June 1, 2009 Author Posted June 1, 2009 Would somebody tell me which head has a plug for the sending unit? Thanks Tommy Cole The left rear head, just inboard of the spark plug. For a photo see this thread... http://www.venturerider.org/forum/showthread.php?t=33268 Dennis
edger Posted June 1, 2009 Posted June 1, 2009 I got too much other stuff up there for all them guages. With GPS MP3 and water holder etc, no room for more guages!
SilvrT Posted June 1, 2009 Posted June 1, 2009 Today was quite warm (around 28 celcius) and we were on the "Ride for Dad" run. The first leg of the route took us thru downtown Vancouver, across the Lions Gate bridge and into West Van. There were over 2000 bikes! ... I barely got the bike out of 1st gear during that time and my temp gauge was pushing 230. I wasn't concerned coz it would get up there and then drop back down a bit so I knew the fan, etc was doing it's job. Besides, there's got to be some room for error on a gauge set that costs $39.95 for the whole set. Generally tho, it sits right at 210 on a warm day at highway cruising.
Monsta Posted June 1, 2009 Posted June 1, 2009 Not so. Standard operating temperature for the RSV is 210 F.....the shop manual states the thermostat does not reach full open position until 203 F. Goose For real? Why so hot? That's hotter than my past bikes and any of my 4-wheeled vehicles.
AlbertaClipper Posted June 3, 2009 Posted June 3, 2009 Just got back from a 14 hour ride from Salt Lake City to Medicine Hat, Alberta. My temperature gauge cycled from 210 to 230 constantly. It took about 30 seconds to go from 210 to 230. Then about 10 seconds to go from 230 back to 210 as the thermostat opened. I don't think the numbers are accurate (as stated above what do you expect from a $20 gauge) but it did show a definate cycle. FWIW
Jactana Posted June 25, 2012 Posted June 25, 2012 Just got back from a 14 hour ride from Salt Lake City to Medicine Hat, Alberta. My temperature gauge cycled from 210 to 230 constantly. It took about 30 seconds to go from 210 to 230. Then about 10 seconds to go from 230 back to 210 as the thermostat opened. I don't think the numbers are accurate (as stated above what do you expect from a $20 gauge) but it did show a definate cycle. FWIW Mine does the same thing, and living in Kamloops heat, it's pretty much like that all the time.
