Guest 05RSMVTEXAN
A while back I thought I read where someone was able to get their TOMTOM RIDER to play through their sound system on the bike. Does anyone know if this can be done? Thanks, Mike
I have the TomTom Rider 2nd Edition and I don't think it can be adapted since it doesn't have a readily available audio out port, but if anyone knows of a mod I would be interested.
There is a way to do it because I have it on my 06 midnight. It is an itegration system for the tomtom and I thought I purchased it from Sierra Electronics, but can't find it now. This system pugged into the headset harness under the pass. seat and power from the battery. One cable ran to the trunk and had plug to charge the TT bluetooth and another end that plugs into the audio out on the bluetooth. Here is a link to Sierra http://www.sierra-mc.com/proddetail.asp?prod=JM%2DCFRG%2DBT01 . I think this product may have replace what I have and would do what you need.
Ok, I found the info for you. What I have is the Kennedy Cellset and I purchased from cyclegadgets.com . They don't seem to have that modle anymore so I did a search and found the kennedy site here http://www.cellset.com/Motorcycleitems.html . You need this modle CellSet MC/SP4 . Click on this model and then click on the harness and phone harness. You need the 5pin din modle fpd and under the phone harness you will see one for the tomtom rider. This set allows you and the passanger to use the phone thru the tomtom and also hear the voice directions thru the intercom system. It is a little pricey and has gone up since I purchased mine. The new bluetooth adapter in the prev. post may be all you need and is a lot cheaper. Hope this helps.
